What alternator bracket am I missing I need them asap ???
Old July 24th, 2017, 08:07 AM
Beamin23's Avatar
Beamin23 is offline
Old July 24th, 2017, 08:15 AM
Beamin23's Avatar
Originally Posted by toymobile
I'm sure I have what you need but back away a little and take another pic.
Johnny
what alternator bracket part do I need ?
Beamin23 is offline
Old July 24th, 2017, 08:17 AM
Beamin23's Avatar
Beamin23 is offline
Old July 24th, 2017, 08:21 AM
lemoldsnut's Avatar
To help solve your problems a farther back picture of the entire engine and some more info on what it is you are working on would help. Also what part of the world are in? It helps to know so someone close might be able to help you directly?
Larry
my guess is you need the H type brackets but need more info.
Direct email is best for me
lemoldsnut@aol.com
lemoldsnut is offline
Old July 24th, 2017, 08:26 AM
Olds Fever
CRUZN 66's Avatar
What vehicle type & engine info would be helpful?
CRUZN 66 is offline
Old July 24th, 2017, 08:31 AM
Beamin23's Avatar
its a 72 cutlass 455 with j heads
Beamin23 is offline
Old July 24th, 2017, 08:35 AM
Beamin23's Avatar
Larry
lemoldsnut@aol.com
Beamin23 is offline
Old July 24th, 2017, 09:11 AM
toymobile's Avatar
Here is the one I have,$20.00 shipped in the lower 48.
Let me know
Johnny
toymobile is offline
Old July 24th, 2017, 09:16 AM
You have 307 alternator brackets on a big block Olds. You have two issues. First, you are missing the 307 lower bracket. Second, once you get that bracket, you will need to fabricate a 1" spacer between that bracket and where it bolts to the PS pump bracket. The 307 brackets are only designed to fit the small block Olds. Your BBO has a 1" taller deck height, thus the need for the spacer. The 307 bracket also incorporates a jackscrew to aid in tightening the belt.
joe_padavano is offline
Old July 24th, 2017, 09:23 AM
I consolidated all your posts into one thread. It is neither necessary nor in your best interest to shotgun the same question into multiple threads, and it is especially confusing when you hijack someone else's thread about a 1967 alternator bracket that doesn't apply to your situation. That thread has already had bad answers posted due to the confusion.
Old July 24th, 2017, 11:29 AM
Beamin23's Avatar
ok thanks for the info
Beamin23 is offline
Old July 24th, 2017, 01:15 PM
Joe, I am not familiar with those brackets. Is the empty hole on the power steering(?) bracket part of that, or is there supposed to be a horizontall brace there?
Fun71 is offline
Old July 24th, 2017, 02:25 PM
Yes, exactly. The triangular bottom bracket bolts to that hole on the PS pump bracket and also to the front bolt on the exhaust manifold (where it replaces that horizontal strut on the earlier cars). The bolt to the PS pump bracket is where you need to insert the 1" spacer to use this for a BBO application.
442mark
September 30th, 2017 01:06 PM
nj67
July 24th, 2017 12:37 PM
DoubleU30
November 10th, 2012 04:09 PM
xerxes600rr
August 30th, 2011 06:43 AM
TK-65
February 11th, 2011 02:14 PM
Quick Reply: What alternator bracket am I missing I need them asap ???
