Considering '56 Super 88
We are looking at a '56 Super 88, but it is missing a few things: valve covers, carburetor and power steering pump cap. Are any of these items hard to find? Trim is all there and the body looks okay, but it will need floor pans and interior.
We would appreciate any guidance any of you might offer. Thanks.
Welcome aboard. Those Items,valve covers, carburetor and power steering pump lid can be found on Ebay quite often but don't limit your search to Oldsmobile or just 56.Valve covers will fit from 54 to 56 (acturally earlier will also fit but are lettered differently) and the 4gc carburetors can be sourced from Buick as well as Oldsmobile for a number of years before and after 56..... Tedd
Thanks. I was a bit surprised not to find any offered when I looked, but it's only been a day or 2. The other issue is my project partner (younger son) is not enamored with the original color of this particular car (Citation Bronze with Shantung Beige) and I am pretty set on taking it back to original specs. Other than that it meets our needs, so this car may be the one.
There are a lot of good things to be said about 56 Super 88's, and a lot of parts out there. Give us some more information about the car, and show us some pictures. We'll be happy to help you out.
Color of a car is a subjective and personal thing. Putting a car back to what the cowl tag reads is commendable but certainly not written in stone. My car originally was a puke green off white single color car, it wasn't going back to that color ever. If you like your cars color by all means keep it original, if not change it to something else Oldsmobile offered ( first choice) or something else you or your son likes. If you choose wisely the value of your car will rise according and if kept a stock Oldsmobile color even though not born with that color you won't even lose points at a National show.... Just my thoughts.... Tedd
PS. We do like pictures.
I will post pictures if we buy the car. At this point I only have those on craigslist and a few additional photos sent to me via text. As for the color, I am not strictly opposed to changing from the original, but still prefer to stick with the way it left the line.
Update:
After looking around a bit more, but finding no more attractive options, we are off to look at this car in person this week. If it is in the condition we predict, this is probably the one. I will post some photos once we have it home and cleaned up a bit.
The original Carburetor would have been a Rochester 4gc as someone in an earlier thread has said. If you will search EBay for Rochester 4gc Carburetor, there are multiple ones listed.Most of them are used and are sold recommending a rebuild.Kits for these are easily located. Best of luck with your purchase,and you are very lucky to find the year and body style you were desiring,especially with air conditioner and a nice interior. Larry
Okay, we did buy the car. It's rough, but was not expensive, and is pretty complete. It is a Doraville built car, which is interesting to us, and also appears to have been sold by Mitchell Motors here in Atlanta. I drove past the Doraville plant at least a million times over the years, and vaguely recall the downtown Atlanta Mitchell location. It also once belonged to someone working at the Redstone Arsenal, so it was a Rocket powered Olds at a rocket base.
Several of you have already offered to help, and we really appreciate that. We'll certainly need more before this is over.
'56 Oldsmobile Super 88
A bit late, but here she is on the way home. We have been tearing the car down and collecting known missing items for the last few months. Several posters here have been helpful with parts and I thank you for that.
Yesterday we discovered that the block is scrap iron thanks to a broken piston that resulted in the #3 rod through the bore. We will likely try to find another '56 block and build it, but are considering alternatives at the moment.
I will be posting in the Parts Wanted section for that.
If it were me I'd be looking for a 371 Olds 1957- 1958 to slide in there. First generation motor so it will bolt up to a Jetaway transmission, Gets you about 300 HP without doing much of anything,and looks as stock as a 324 but goes like scat.
I would check out that rusted area between the back side window and back rear window. This could be a major problem if the rot has taken over and not a easy fix, It may not be as bad as it looks but something you should check before you drop a bunch of cash in that car then find out the rear window frame is dissolving from the inside. JMHO..... Good luck and keep us updated.....Tedd
Redstone stickers on front and rear bumpers. Both say "CCL48." I have no idea when that may have been. I'll get a picture uploaded.
Barsteel
September 17th, 2010 01:51 PM
