Tic toc tac Rally Pack installation 72 clone
Old June 9th, 2016, 08:52 PM
J Morel's Avatar
On the tac wiring I am to change the wiring order per directions to match the tach by removing the pins in the connector....does the tach have the color codes on it or is there a left and right side of the connector? Anything I should be aware of while performing this task will be appreciated.
J Morel is offline
Old June 10th, 2016, 07:56 AM
"Trying to fix her right"
dfire25's Avatar
For the tac itself, you just need to install the shielded fused wire to the negative side of the coil. Then connect the orange wire for the clock, (constant power) and the grey wire for the lights. There are no pins or plugs to switch around unless your installing the gauge pod.
dfire25 is offline
Old June 10th, 2016, 08:38 PM
J Morel's Avatar
Your right, I am asking about the gauge pod.
J Morel is offline
Old June 10th, 2016, 09:53 PM
dfire25's Avatar
Then your original post is confusing then. Anyway, yes, you have to change the wires around. They should be in the instructions. Otherwise, here's a pic of how the wires should go.
File Type: jpeg
dfire25 is offline
Old June 11th, 2016, 07:58 AM
J Morel's Avatar
Thanks for the diagram dfire25! A pic is worth a thousand words! You are really good at this....may I ask another question....what is the extra short wire (on the interior end of the braided tach wire with the in/line fuse), perhaps a ground?
J Morel is offline
Old June 11th, 2016, 08:02 AM
Texas69's Avatar
Yes, it is a ground wire.
Texas69 is offline
Old June 11th, 2016, 08:11 AM
dfire25's Avatar
Thanks J Morel! But 90% of my knowledge comes from the people on this forum. The other 10% is going out there and doing it myself.
dfire25 is offline
Old June 12th, 2016, 08:05 AM
J Morel's Avatar
Thanks indeed to you and the forum! I re-routed the wiring on the gauge pod yesterday per valuable diagram. I re adjusted the barb on each wire before re-enserting the wire into the connector to ensure proper hold. Now, I need to know where all this wiring is routed thru the firewall??
J Morel is offline
Old June 12th, 2016, 08:23 AM
dfire25's Avatar
The only wire you should have to run thru the firewall is the tac wire to the coil. The other wires for the temp and oil pressure gauges are ran thru the factory wire loom. When you install the temp and oil sensors into the engine, the wires should be by the old idiot light sensors. I memory serves me, I think it's a green wire for temp, and blue wire for oil. But I might have that backwards.
dfire25 is offline
Old June 12th, 2016, 01:15 PM
J Morel's Avatar
Once again, thank you. I assume the coil wire location is the same bushing hole in the firewall the speedometer cable uses?
J Morel is offline
Old June 12th, 2016, 06:17 PM
dfire25's Avatar
Nope, there should be a square hole with a plastic plug right around where the throttle cable goes thru.
Actually I just found this thread.
https://classicoldsmobile.com/forums...eded-asap.html
dfire25 is offline
Old June 24th, 2016, 05:35 PM
J Morel's Avatar
One last wire to deal with on the rally pack installation. According to #6. per instructions, I need to cut or disarm a green wire under the dash column ribbon. I will atach their written instructions with bad pic. Will also take a pic of my own area they are describing. Hopefully someone will describe what green wire I need to cut in a better pic or description. Thanks in advance.
Can anyone see a cut green wire in this photo?<br/><br/>
This is my pic of the same <br/>area.
J Morel is offline
Old September 28th, 2017, 11:44 AM
Joe Ralph
72442455's Avatar
dfire25 - the grey wire that comes out of the illumination feed on the back of the tach connects to what exactly? (72 convertible) I am having a heck of a time with that - I have the service and body manual - but all I can tell is “grey wire” any help would be appreciated - thanks ~ Joe (update - I found it - it’s the grey plug from the wiring harness)
72442455 is offline
Old September 29th, 2017, 07:35 PM
dfire25's Avatar
Yep, that's it.
dfire25 is offline
Old October 5th, 2017, 07:34 AM
Joe Ralph
72442455's Avatar
Thanks!
72442455 is offline
Old October 5th, 2017, 09:42 AM
oldspackrat's Avatar
I installed an aftermarket tach & gauge set in a customers car a few months ago & it said to cut the green wire under the column. Right after that, the right rear lights were inop. Turns out the green wire is for those lights. We reconnected the wire & everything works like it should, so I'm not sure why those instructions are not there but you may not want to cut that wire.
Also, I think you were asking about tach wire routing? The braided wire should exit the interior of the car to the right of the master cylinder as you're looking at the engine. There is a rubber grommet with 3? indentations/holes in it. Then it should be routed above & behind the booster & over to the coil.
oldspackrat is offline
Old March 19th, 2018, 02:52 PM
moriver's Avatar
Hi, I am a littlebit confused about this. My 70 Cutlass supreme had the "Idiot light" fuel gauge, but the wiring is exactly like it is shown to be in the Figure shown as "Gauge Wiring", which is strange, or what? Have bought rally pack to install. Brgds Morten
moriver is offline
Old September 15th, 2018, 03:29 PM
pfergy600's Avatar
Location: 25 miles North of Tampa, Land O' Lakes, Florida (Originally from Bethpage, Long Island, NY)
I have a 72, with the tic tac tic guages (no idiot lights). My Tac is not working, any suggestions on what I should look at first? I'm not that mechanically inclined so go easy, lol.
Thanks in advance.
pfergy600 is offline
Old September 15th, 2018, 04:00 PM
Have you tested the ground, and also the inline fuse?
Allan R is offline
PHILATLAS
April 7th, 2017 08:36 AM
jlauffer
July 10th, 2015 08:51 AM
Joker442
March 31st, 2012 09:09 PM
jowilla442
February 19th, 2010 11:55 AM
nelsontj
February 22nd, 2009 07:10 PM
Quick Reply: Tic toc tac Rally Pack installation 72 clone
