New member help rocket build
Old March 4th, 2013, 06:12 AM
supamario601's Avatar
I have a oldsmobile 350 rocket gold engine came out of like a 75 olds tornado complete rebuilt bored .040 complete valve job new guides upgrades spings to match with new mild steet comp cam new timing chain I mean the works. My engine just isnt giving me the power I think it should have and i believe it has alot to do with my timing/tuning I wana know wat is the best way to find your best timing for you engine and i do have a distributor with the curve kit also any help provided is greatly need!
supamario601 is offline
Old March 4th, 2013, 06:58 AM
jaunty75's Avatar
It's Toronado, and this can't be correct. The only engine available in the '75 Toronado was the 455. In fact, the Toronado never came with a 350 in any year.
jaunty75 is offline
Old March 4th, 2013, 08:36 AM
Im not exactly sure wat it came out of im just goin on wat the guy said i got the engine from and im sure its around those years because when i bought the arp head bolts at first i had to the wrong ones "the smaller ones" and I was informed then that a i had a early 70's model motor
Old March 4th, 2013, 08:37 AM
and also it was a front wheel drive engine also but thats really beside the point im look for tunning help
Old March 4th, 2013, 09:34 AM
Starting in 1979 when they first downsized them, they came with a 350. Supermario, you need to i.d. your engine, look at the casting numbers on the shelf behind the water pump. There is a pad below the No.1 cylinder (front drivers side), post that here and it can i.d. the year.
1969w3155 is offline
Old March 4th, 2013, 09:42 AM
jaunty75's Avatar
You're right! My mistake.
jaunty75 is offline
Old March 4th, 2013, 09:59 AM
I had a '79 and I still like the darn things!
Old March 4th, 2013, 06:29 PM
5577523B above my water pump
Old March 4th, 2013, 07:13 PM
GM Enthusiast
OLD SKL 69's Avatar
Welcome to CO. If it came out of a Toronado, it is either a 79 or 80 engine. As far as your problem goes, can you give us more specifics on your fuel/ignition setup? Stock HEI setups are generally not geared for performance and if yours is stock, that would be one of the first places I would look to modify.
OLD SKL 69 is offline
Old March 4th, 2013, 08:02 PM
I have a 1406 edlebrock with performer rpm intake new distributor bottom with accel curve kitand high performance coil but I do have stock wires and alternator o and manual fuel pump wit glass filter
Old March 4th, 2013, 10:20 PM
Appears to be a 1977-1980 350.
Old March 5th, 2013, 06:20 AM
Update I moved my timing up to 22 initial now she's sucking gas but hauling a** lookin for that perfect combination
agreen316
December 21st, 2013 06:27 AM
wildwillie1981
April 24th, 2013 04:19 PM
66442ragtop
April 9th, 2008 02:31 PM
69 442 protour
December 9th, 2006 09:25 PM
bigshot846
November 22nd, 2006 07:57 PM
Quick Reply: New member help rocket build
