I WAS RECOMENDED TO GET THE HOLLEY DOUBLE PUMPER Is that a good choice!??.
Old March 23rd, 2014, 09:54 PM
4door!cutlass's Avatar
Hello an thanks for your time,i have a 455,400 trans,mild cam and will be going with 3.55 rear . i was told to go with a 650 double pumper.
i will be going with edelbrock rpm.i was told to start. with 650 so i wont over gas .so if i need more gas i can jet it.
so what do you think will be the best carb.
4door!cutlass is offline
Old March 24th, 2014, 04:35 AM
Shanghai Smith's Avatar
I think a Q-Jet would be a better choice. Here is a link to SMI I have one of their carbs on my 403 and it works very well for the street and at the strip with a 150 shot of nitrous.
http://www.smicarburetor.com/product...D2/9/sfID3/100
Shanghai Smith is offline
Old March 24th, 2014, 10:00 AM
tmaleck's Avatar
Sound like too much carb to me. I would stay with vacuum secondary single pump on a manifold like that. Too many folks over-carb. I'd look at a Holley 650 street avenger. Also, look for a book by David Vizard on tuning Holley carbs. Lots of great info on carb selection and tuning. If you're not into carbs, a 1406 Edelbrock might be a good choice.
Tim
tmaleck is offline
Old March 24th, 2014, 10:43 AM
chadman's Avatar
You didn't give a whole lot of information on the rest of your combo so I am going to assume it to be a basic 455 with stock heads and a very mild cam that will be going into your 4 door in your avitar and will just be cruised around on the street. If so I would not suggest a double pumper carb of any size for that application. I would either run a Q-jet or a Holley model 3310 which is a 750cfm vacuum secondary.
chadman is offline
Old March 24th, 2014, 11:02 AM
Beob's Avatar
Ive been running a Holley 750DP for 25 uears and I love it. I had it on a 455 G head solid lifter mild cam 9:1 comp 3.31 gears. when the secondaries open up it just screams. If you're looking to roast you're tires and do donuts you'll be very disappointed with a vacuum sec.
Beob is offline
Old March 24th, 2014, 11:03 AM
Run to Rund's Avatar
I agree with Chadman.
Run to Rund is offline
Old March 24th, 2014, 12:02 PM
That has not been my experience. I have done lots of tire roasting and dounts with a vacuum secondary carb.
Fun71 is online now
Old March 24th, 2014, 12:04 PM
Mr. Johnson
rjohnson442's Avatar
If not worried about gas mileage I'd go with the Holley 750DP. You'll be very happy if you add an intake and a spacer down the road. I'm running an 850 DP on a 461 and almost flinch when the secondary open up.
rjohnson442 is offline
Old March 24th, 2014, 12:14 PM
delete
droptopron's Avatar
Another variable is torque converter. If you have a higher stall speed it will be much more forgiving of a double pumper.
droptopron is offline
Old March 24th, 2014, 12:18 PM
chadman's Avatar
That's why they make the vacuum secondary sytem tuneable. For the record I have a 850 DP on my '65 but I think it is a bit more radical than what the OP has and it spends a fair amount of time at the dragstrip.
chadman is offline
Old March 24th, 2014, 12:42 PM
Beer Connoisseur
70cutty's Avatar
I agree with chadman too, 750 vac. secondary will do the job on a stock or near stock 455.
70cutty is offline
Old March 24th, 2014, 12:44 PM
major noob
billmerbach's Avatar
I agree as well if everything is gonna be mostly stock why sacrifice gas mileage if you have nothing to back it up with. I mean go dp if you are gonna go with upgrades in other areas but don't waste time and money both now and later on gas for something that won't add much power I hope I stated that right lol
billmerbach is offline
Old March 24th, 2014, 01:03 PM
Keegan's Avatar
One of my buddies has one of these on his '79 Camaro, and it seems like it's a pain to get tuned right. Maybe it's just his lack of experience and trying it "trial-and-error" on his own, but the thing stalls out in revere and seems to dump WAY too much, trying to flood the engine.
Keegan is offline
Old March 24th, 2014, 02:23 PM
Mr. Johnson
Pumps are adjustable with kits and yes a DP can be a pain to get it in tune. But once you do
Old March 24th, 2014, 02:51 PM
Ok,so many different options,my 455 has stock heads,bored over 40,mild cam.will be getting edelbrock rpm air gap intake upgrade. probably going with 3.55 gears .i have g heads,the moter comes from a 71 delta 88.
i like the holley avenger 4150 750manual. i never even herd of vacume.i plan on driving the car daily .i do like decent gas milage.so I'm just not shure what carb is the right one.
Old March 24th, 2014, 02:56 PM
QUOTE=chadman;673441]You didn't give a whole lot of information on the rest of your combo so I am going to assume it to be a basic 455 with stock heads and a very mild cam that will be going into your 4 door in your avitar and will just be cruised around on the street. If so I would not suggest a double pumper carb of any size for that application. I would either run a Q-jet or a Holley model 3310 which is a 750cfm vacuum secondary.[/QUOTE]
Old March 24th, 2014, 03:09 PM
Tim
The avenger was my firsts choice,what size do u recomend
Old March 24th, 2014, 03:31 PM
I see that chadman got the most votes.i herd that vac.secondary tends to stall when trying dump the petal.which system is less likely to bogg when dumping.
Old March 24th, 2014, 03:49 PM
drjr56's Avatar
You'll get the best of both with a properly set up QJ on that car. I run a 750 vac secondary Holley on my 455 no problems.And break the tires loose at 25mph in drive.Gas milage is so so....until I get on it. QJ gives you decent mpg and performance on what you have.My 400 with a mild rebuild has a QJ and runs just fine.
drjr56 is offline
Old March 24th, 2014, 03:51 PM
azure blue 442
dmullin's Avatar
Vacuum secondary bog
The vacuum secondary will never bog out if adjusted correctly. It provides smooth power delivery when transitioning from 2 to 4 barrels. Excellent design for the street, especially with an auto and tight converter.
A 650, really! The cubic inch/volumetric efficiency and rpm band would dictate a need for a 750 if you plan to see power up to 5500. IMO.
Too much carb is bad, I agree... Don't discount a well built quadrajet.
dmullin is offline
Old March 24th, 2014, 04:12 PM
Even by Holley's standards it's recommended you use a vac secondary 750cfm carb. You can play with their recommendations yourself below.
http://holley.com/applications/Carbu...bSelection.asp
oldcutlass is online now
Old March 24th, 2014, 05:35 PM
You probably heard that from someone who doesn't know how to properly adjust the vacuum secondary operation. As dmullin posted, when properly set up there is a smooth transition with no bogging. Lots of us with vacuum secondary carbs can attest to that.
Fun71 is online now
Old March 24th, 2014, 05:40 PM
Senior Moment Member
z11375ss's Avatar
I like my setup. Holley 780 DP. Manual trans, 3.73s. Perfect. Your setup? Sounds like a QJet is the way to go. Some economy and a lot of get up and go.
z11375ss is offline
Old March 24th, 2014, 05:47 PM
jag1886's Avatar
No dp!
jag1886 is offline
Old March 24th, 2014, 06:08 PM
Old March 24th, 2014, 06:12 PM
They ask for engine size an max rpm.i don't know the max rpm.and thanks for yur time
Old March 24th, 2014, 06:15 PM
major noob
Max rpm shouldn't be more that about 5500 am I right
Old March 24th, 2014, 07:15 PM
Tim
Old March 24th, 2014, 07:27 PM
The avenger was my firsts choice.even though i will be driving the car i plan on doung a head upgrade and start playing at the track, i want speed but still keep it street .the guy that will be working on the car is highly respected and builds race cars. he told me the double pumper is what I'm looking for so I'm stuck between the avenger an the dp.
my head is spinning .
Old March 24th, 2014, 08:12 PM
I deleted your other thread as a duplicate. Your not going to get different answers.
Your engine size is a 455 and your rpm should be 5000. Mild build, street use, pay attn. to the notes about the DP vs vac secondary.
Old March 24th, 2014, 08:25 PM
  #31
Ok,I'm new to all this stuff so i know nothing about rpms.so what is your openion on the dp vs.vac secondary .and i take it that u are saying the 455 rpms are 5000 or that the goal is 5000 rpms?.
Old March 24th, 2014, 08:42 PM
  #32
some one said what are your rpms what?
I'm not understanding what people mean about rpms. I have a 455 and need the right carb,so when someone. sais u need 5000 rpms. is that the goal rpms that i need with the carb or is that what the 455 produces?.
o yea stop giggling I'm new to this.lol
Old March 24th, 2014, 08:44 PM
  #33
I'm not understanding what you're asking.
MDchanic is offline
Old March 24th, 2014, 08:56 PM
  #34
The reply was this:Your engine size is a 455 and your rpm should be 5000. Mild build, street use, pay attn. to the notes about the DP vs vac secondary.
So I'm asking what does he mean,your rpm should be 5000.
Old March 24th, 2014, 10:16 PM
  #35
TripDeuces's Avatar
My two cents:
1) QJet
2) Holley vacuum secondary or an Edelbrock
You mention you're going with an Air Gap manifold. That's tall and will require AC bracket modifications to fit if you have AC. It's also rated for 1500-6500 RPM which you're never going to see with your set-up. If that is the Cutlass in your sig that you're putting all this into then I'll bet it's too tall with that manifold and will require cutting the hood. You need a nice low rise dual plane and a new mechanic or at least stop taking his advice. Stick with the QJet and stock for now.
TripDeuces is offline
Old March 24th, 2014, 10:30 PM
  #36
z11375ss's Avatar
The Air Gap fits on my setup. It's tight, but it does fit.
z11375ss is offline
Old March 25th, 2014, 12:21 AM
  #37
Alex72cutty's Avatar
I was thinking about using the air gap for my 72 cutlass.
Alex72cutty is offline
Old March 25th, 2014, 12:41 AM
  #38
'87 Delta 88 Royale
rustyroger's Avatar
The rpms (revolutions per minute) you need from your engine will depend upon what you want it to do.
If you want horsepower for screaming down a drag strip you will want lots more rpm than if you want stump pulling torque for towing a heavy trailer.
So what are you going to use the engine for?, bear In mind the higher the rpms tou want the more strain there is on moving parts, particularly pistons and rods. To build a 455 Olds engine to run at 5000 rpm for any length of time will be expensive, either because to build one to handle it will require strengthened quality parts, or because the engine won't last long if you leave it as standard.
The carb you require is also dependant on what cam you use, compression ratio, exhaust system and other factors.
Let us know what modifications your engine has and what you want to use it for and you will find plenty of well informed help and advice here from people who have lots of experience building engines successfully.
Roger.
rustyroger is offline
Old March 25th, 2014, 01:19 AM
  #39
No major modifications other than a rebuild,bored 40 over and a mild cam upgrade.I'm just wanting to be able to smoke any average car if someone tries me at the stoplight!.
Old March 25th, 2014, 02:45 AM
  #40
Originally Posted by TripDeuces
My two cents:
1) QJet
Quick Reply: I WAS RECOMENDED TO GET THE HOLLEY DOUBLE PUMPER Is that a good choice!??.
