My 68 442 Convert Restoration
Old October 25th, 2014, 10:31 AM
Gary
Gary's 2 442-S's Avatar
I have begun the restoration of my 68 442 convertible. Just wanted to share with you guys some of my progress. Got the car in January of this year and began working on it in March. My plan is to have this car completed by March of 2015.
Here is what the car looked like when I got it.
Ok here is what I have done so far. The worst thing to do on the outer wheel housing is to cut the whole thing off. Unless its completely rusted. I should have just cut off the bad portion and welded the replacement in. Had to use a outer for a hardtop which is ok but don't cut the entire outer off. I ended up messing up one new housing while trying to modify.
Sorry but I guess I have lost the pictures of the outer wheel housing. But here it shows where I put the quarter on. I did but weld it. Here is what the weld looks like inside the trunk.
This is what the seats looked like. Pretty rusty
got plenty of more pictures. don't want to try to load all on this one post. Uploading the others now.
Gary's 2 442-S is offline
Old October 25th, 2014, 11:05 AM
Gary
this frame I had to fix the badly rusted part of the frame. Cut of the bad portion and welded a new piece in.
this is what they looked like after I sandblasted them.
Started painting them with Por15.
So after the blasting and painting of the seat frames I too the seats to my upholstery man. Told him I wanted leather seats. So here is what they look like now. Thought he did a great job. Could not get the "diamond" looking material so I choose to go with same leather all over. But the pattern is correct.
Next week my plans is to pull the engine and then remove the body off the frame and take it to be powered coated. Not really sure what I am going to do about the engine just yet. I went and talked with the guy who rebuilt my last engine and he asked me how did the engine run. I told him it ran really good. His suggestion to me if it was running good, then he doesn't think I need a rebuild. I was surprised at that. But just might let him redo the heads. Now he did say he would rebuild it but it probably doesn't need it.
Old October 25th, 2014, 11:19 AM
Gary
Here are my bumpers that was done by a shop here that does work for Jay Leno. The rear one was bent and they did a really good job fixing it. It also has holes for a trailer hitch which I choose not to have plugged up.
Decided I would purchase a body rotisserie. I was going to build one but decided just to purchase one.
Old October 25th, 2014, 11:24 AM
Gary
I also ordered the door panels from Legendary. It took the about 5 weeks to build them. They are now being shipped. I will post some pictures of them once I get them.
Old October 25th, 2014, 01:16 PM
Randy C.
rcorrigan5's Avatar
I am enjoying your pictures and look forward to watching your progress. Your restoration plan is much more aggressive than mine. I took 2 1/2 years. It seemed to take forever, getting parts ready. But every once in awhile, when several things were ready to install, it seemed like there was a big flurry of accomplishment. Then it would go back to getting more parts ready. You'll enjoy the end product, though...I know I do!
Randy C.
rcorrigan5 is offline
Old October 25th, 2014, 01:28 PM
Lookin good! The seats turned out nice.
oldcutlass is online now
Old October 25th, 2014, 02:07 PM
allyolds68's Avatar
The seats are a nice touch. I bet you have some cash in those.
How's the rest of the body? Have you taken it off the frame yet?
allyolds68 is offline
Old October 25th, 2014, 02:45 PM
Gary
Randy C.
Yes, really going to get at it since the heat here in Houston is gone. Took my 5 years on my 72 restore but I was working and only worked on it on Saturdays. I retired from my job after 32yrs at the beginning of the year so, I can devote a lot of time to this one. My new job lol.
Old October 25th, 2014, 02:47 PM
Gary
Thanks Eric, the seats really came out good. The guy did a good job duplicating the pattern.
Old October 25th, 2014, 02:53 PM
Gary
I have stripped the remaining body shell. Looks good as far a damage/rust. I plan on taking the body off the frame next week or so. Good thing about this body is I don't have to replace the trunk or interior floors. Had to do both on my last restore. Yes I do have some $$ tied up into the seats. I could have gotten the covers from Legendary but I wanted leather seats.
Old October 25th, 2014, 06:04 PM
Boilerz25's Avatar
Coming along nicely. The seats look great!
Sean
Boilerz25 is offline
Old November 8th, 2014, 01:03 PM
pitfield1's Avatar
Great job Gary. I noticed you only cut the quarter panel a little above the wheel well. I'm planning to do the same.When replacing the whole panel members are saying some shrinking needs to be done. Did you have to do much modification to the quarter to get the proper fit? Looks real good
Dave 69 442 convert
pitfield1 is offline
Old November 8th, 2014, 01:09 PM
Gary
Thanks Joe,
I don't have any recent ones, I have been getting the 72 ready for Autorama. But I will start back on it in a couple weeks. Next step is to brace the body and then put the body on the rotisserie. Plan on taking the frame to powered coating.
Old November 8th, 2014, 01:21 PM
Gary
Dave 69 442 convert
Dave thanks,
Actually I ended up cutting it higher probably a couple inches below where the holes are for pinch well moldings. I for some reason could not find my pictures of how far up I cut it. But if you look at the picture of the inside the trunk area, you can get an idea about how far up I went. All the welds were butt welds. As you know they don't make a quarter for the 68/69 converts. You have to use one for a hardtop. Also unless your outer wheel well is completely rusted don't do as I did and cut the whole thing off. You will regret it. 69442C has a really good thread on the quarter/wheel housing replacement. https://classicoldsmobile.com/forums...n-project.html
Old November 8th, 2014, 01:39 PM
Gary
Originally Posted by gh5168
Dave thanks,
Old November 9th, 2014, 06:47 PM
Eddie Hansen's Avatar
Gh nice work so far, I am just in tge process of hanging the quarter, I already spliced the outer wheel house, man you must have been drilling spot welds for days getting that ***** off lol... mine was in really really good shape I cut mine on the curve asiheard curves are harder to warp.
Pitfield
the quarter from goodmark year onefits pretty darn good, iam doing my quarters now, just saying,
G also lovetye bumpers man.... shiney....
Following along....
Eddie Hansen is offline
Old November 9th, 2014, 09:43 PM
Gary
Pitfield
Following along....
That housing was a PITA to get off and a more PITA to get on. I went at the wrong way. I will be following your progress as well. The quarter was not that difficult. Just a lot of fitting on and off.
Old November 10th, 2014, 01:24 AM
Randy C.
rcorrigan5's Avatar
I had to replace the driver side quarter on my '68 - an accident my wayward sister had several years ago made a mess of that area. The body shop that did the work cut out most of the quarter and used a repro quarter for a hardtop cut to fit. That happened 7 years ago and it still looks great to this day. That effort got rid of bondo that was nearly 1/2" thick in spots.
Randy C.
Old November 10th, 2014, 05:13 AM
I hear you.. I have the repo quarters , when I clamped the new over the old the marker light matched exact, so I removed all the way back and to the front inner brace by the door jamb, still considering welding it into the jamb just seeing how the gaps will be.
And I reade and reread brians 69, thread ask myself all the time what would. Brian do lol. Anyway I f
Regress love the progress.
One question gary did you use gas or flux wire ? Was looking at the smoke patterns I didnt get that ?
Old November 10th, 2014, 08:13 AM
Gary
I used gas. I think the smoke pattern is because I used a lot of tac welds. I did not want it to warp. Yes Brians thread is a really good source on how to do it. I like what was done on Randy's 68 as well.
Old November 10th, 2014, 10:07 AM
Thanks me too, was wondering if I was doing something wrong lol.... I am new at mig, last time I replaced metal was with acetylene LOL... and yes we rubbed two sticks together to light it..LOL...
Old September 12th, 2016, 10:21 AM
Gary
I have not posted anything lately, I had a severe injury to my thumb that required reconstructive surgery last year and pretty much kept me from doing much to the car. But now recovered from the injury I began to work on the car once again. Here is some of my progress.
After I had the frame sand blasted. They use walnut shell.
I primed it with epoxy primer see below
Began to paint it with Eastwood extreme chassis black
I had the rotors turned and decided to restore them myself. I believe these to be the original ones.
more pictures to come.
Old September 12th, 2016, 10:34 AM
Gary
I tried putting some of the factory markings back on the frame. Still in the process but here are a couple.
Old September 12th, 2016, 10:53 AM
Gary
Before and after of the front brakes.
Old September 12th, 2016, 10:57 AM
Gary
The Trunk.
Old September 12th, 2016, 11:10 AM
Gary
This is what the quarter panel looks like after I finished installing it.
Old September 12th, 2016, 11:15 AM
rob1960's Avatar
Very nice work!!! looks great! Those rotors are probably off a '70 since they have the groove in the middle of them( I might be mistaken but I think '70 was the only year that had the grooves). Your calipers are the '69 up single piston type. The original '68 rotors were 2 pc & the '67-'68 calipers were the huge 4 piston type like the old vettes used. A previous owner probably added the newer disc brake setup,it's an easy upgrade. I added the newer type like yours on my own '68 as they're far easier to get parts for & MUCH cheaper! Your valve covers are on backwards by the way, the notches go to the back for clearance for the power brake booster & a/c box. That "404" on your rear axle should also be stamped on the side of the left rear frame rail next to the frame part# & build date codes. It's your build sequence # for the chassis dept of the assembly plant. Mine had 39 still visible on the rear & it's also stamped on the frame rail. Mine is a Lansing built car.
rob1960 is offline
Old September 12th, 2016, 11:25 AM
Gary
Underneath the body. The undercoating was very challenging to remove. Took quite a while to do so.
Old September 12th, 2016, 11:40 AM
Randy C.
rcorrigan5's Avatar
Now that is some seriously diligent work! It's going to be a beautiful car!
Randy C.
Old September 12th, 2016, 11:48 AM
ben442's Avatar
very nice, keep up the great work
ben442 is online now
  #31
Gary
Thanks very kindly. That is a great possibility about the rotors being a different year and not being original, I am just not sure. The 404 on my rear end was put back in the exact same location they were before I had the frame sand blasted. Maybe they got it wrong back then because the sequence # on the frame is 410. I might change it.
Old September 12th, 2016, 12:28 PM
  #32
Gary
Seat belts were in awful shape. I sent them off to Snake Oyl to get an estimation on cost to restore. Needless to say their price was much more than I was willing to pay. So I decided to do them myself. I removed the hardware and washed them in the washing machine and put new hardware and resewed the belts on my wife's sewing machine.
Old September 13th, 2016, 11:01 AM
  #33
Excellent Work!!
Wow, excellent work, really looks great!!! and your moving right along too!! unlike myself LOL
Old September 13th, 2016, 12:53 PM
  #34
Gary
Thanks everyone for your kind words.
Old September 13th, 2016, 02:00 PM
  #35
BackInTheGame's Avatar
Fantastic work! And awesome progress in spite of taking off so much time for your injury!
I can't wait to see the finished product...
BackInTheGame is offline
Old September 19th, 2016, 09:38 AM
  #36
joesw31's Avatar
I have seen Gary's work in person, and it is awesome!
joesw31 is offline
Old January 24th, 2017, 02:03 PM
  #37
Gary
I have painted the doors and the body. I will be putting the body back on the frame this weekend with the help of my nephews,son in laws and grandson.
Here is a picture of one of the doors. The color is Black Barolo when in the shade looks black but with sunlight on it, it will look cherry/maroon. I will post more pictures when I get the body back on it. It is covered up in plastic since I dont want the paint to get scratched while we are reinstalling it to the frame. I have not painted the fenders or hood. There is work needed on the drivers side lower fender.
Old December 28th, 2017, 03:09 PM
  #38
Gary
Here is further progress of my restoration. I am going to have to do some touch up on the paint because when putting the convertible top back on,my grandson dropped it and I got a couple of scratches on it that is going to have to be repainted. I am going to send the carburetor out for a rebuild. I am also going to send the radio out to have digital electronics installed in it. I also plan on adding the OAI system from THE PARTS PLACE. I know some have said that OAI system is not all that great but I am going to try and see how it works out. Also the convertible top is going to be replaced. I also have to get the right side tail pipe modified because it just doesn't fit correctly. Hope to finish this car by March. Its nice and cool here so I can work on it easier. I also have bought the red front inner fender wells.My wife has been keeping me busy with all her "honey do" stuff and lots of traveling. Otherwise I would be completed by now.
The top has a tear in it. I tried to repair it but I am certainly not happy with it. So it must be replaced
Old December 28th, 2017, 03:14 PM
  #39
Gary
Old December 28th, 2017, 03:20 PM
  #40
Gary
There is a lot of dust on the car. Also I have lots of tape residue on the car because I used masking paper on it to protect it. I should have just used plastic sheeting to cover it.
Quick Reply: My 68 442 Convert Restoration
