1966 442 Front Fender & Fender Well installation
Old January 6th, 2013, 09:07 AM
Nufo's Avatar
Question 1966 442 Front Fender & Fender Well installation
hey guys it's about time to put the front end on my car. I'm not sure of the sequence that I should use. Should I install the front fenders and then install the inner fender wells or should I install the inner fender wells first and then the fenders or finally should I assemble them as a unit on the car? I have the assembly manual to tell me attaching hardware and clearances, but I don't see where it explains the sequence.
Thanks,
Nufo (Fred)
Nufo is offline
Old January 6th, 2013, 09:42 AM
Run to Rund's Avatar
With steel inners, you run less risk of scratching the outer fenders by installing them as a unit. It also can be hard to get all the inner fender retaining bolts lined up afterwards. You won't be installing any bolts beforehand except those running around the wheel well.
Run to Rund is offline
Old January 15th, 2013, 07:13 PM
Tony
archeryshooter's Avatar
I would leave the bolts loose also till everything is lined up and all the bolts are started elsewere
archeryshooter is offline
Old January 16th, 2013, 09:33 PM
Nufo's Avatar
thanks for the responses and I'll follow that procedure. this thing is really
getting close to being done. FINALLY
Nufo (Fred)
Nufo is offline
Old February 15th, 2013, 10:30 PM
Nufo's Avatar
that technique worked great
putting the fenders on with the wheel wells attached went very smooth. thanks for the tip....
Nufo is offline
oldspackrat
February 7th, 2017 08:42 AM
The Bug Man
Body work
August 15th, 2013 12:53 PM
costpenn
October 27th, 2011 11:27 AM
Nilsson
June 21st, 2009 05:52 PM
Quick Reply: 1966 442 Front Fender & Fender Well installation
