Looking for a mechanic in north jersey to swap an engine
as the title stated, i am looking for a oldsmobile mechanic or someone very familiar with GM that can perform an engine swap.
I own a 72 cutlass which currently has a running 350 in it and also own a 455 which was running prior to removal and now its on an engine stand.
I know alot of you guys can do this on your own however I dont have the time or the experience since I want to avoid complications.
please pm me if you know of someone local that will not rip me off, toronado engine will completely stay the same, yes the engine pan/intake are not original to 442/cutlass however dont have the funds at the moment to update to my complete liking. I will have to purchase headers / engine mount(s), and small things here and there.
thanks in advance!
thanks in advance!
the car is at parsippany and the engine at Riverdale... and yes, theres a hoist available where the engine is.
where you located? I was thinking a body shop to do this but if you're for it and have the experience why not and I rather help out a fellow member from here.
pm me your # if interested and we can talk more!
Gee, sounds like fun!
I'm in NJ occasionally, and would be happy to participate if I were there, but, statistically, it's unlikely I'll be around at just the right time.
Joe is a good guy, and can absolutely help you with that job, if he's available.
I've personally seen him rip an engine out of a car in nothing flat .
Am I hoping he can find someone a little closer to assist....
I have personally observed Mr. Joe as he lovingly, and with great care and precision, separated a precious and delicate Oldsmobile engine from its berth and eased it up into the warm, still air, so that it could be cleansed and painstakingly reanimated by the enchanted elves of Tandoor.
Stone cold sober, too.
Better?
yeah, that's the ticket.
I have personally observed mr. Joe as he lovingly, and with great care and precision, separated a precious and delicate oldsmobile engine from its berth and eased it up into the warm, still air, so that it could be cleansed and painstakingly reanimated by the enchanted elves of tandoor.
Better?
- eric
Better?
- eric
Yeah, that's the ticket.
Better?
Better?
Ok a progress report. The 350 is ready to pull. Torque converter bolts were SUPER tight. One trans to radiator line will twist off, heat and spray aint cutting it. Broken ex manifold bolt on 455 came out (barely) with heat and a pipe wrench. Since headers will be used brake junction block needs to be moved to top of frame. Performer intake on order for the 455, that will save some weight. Hope those flowtech headers go on without a fight! Eric you are missing lots of fun!
Thanks, Joe. Yeah, actually, I think I am.
I could have done without changing my wife's rear brake pads, e-brake shoes, and one rotor yesterday in the near-freezing temperatures, and I sure would have had a more relaxing day today if I hadn't had to spend several hours completely disassembling her iphone to change a cracked screen.
Swapping a motor would be like therapy .
The repair just drags on, because there's no way to go fast - getting each screw placed over its hole and aligned, then carefully started, is a new project each time.
I'm just not a "small-work" guy, and this stuff drives me nuts.
I used to get really PO'd building models as a kid, too.
by the way - the directions at ifixit are very nicely illustrated and clear.
Well we are into the swap and today the 350 was lovingly pulled only to find a big chunk of the trans is attached to the block and no longer part of the trans! See pictures below. Looks like a trans swap is in order as well... Its the piece that has the dowel pin hole and one mounting bolt.
Eric, the trans in the Cutlass was a long shaft. It looks identical to the long shaft turbo 400 I have except the tailshaft takes the small yoke and not the large one. I think the tag dated it to 1973. The driveshaft was junkyard labeled Camaro. Its a shortie, any idea what trans this is? Electric kickdown. Just curious.
It's a TurboHydramatic 375, Joe.
Used in the small-block big cars '71-'75 (or thereabouts), while the 400 was reserved for the BB.
It's essentially a TH400, with a different tail housing (long, since this was for B/C-bodies), with an output shaft and tail housing sized for a TH350 yoke instead of a TH400 yoke.
It should have "375" cast into the tail housing somewhere.
Valving will probably be about the same as a 400, and I suspect some light-duty parts in the clutch areas.
Most of it will interchange with a TH400.
Other than the slipyoke, it should interchange perfectly with any long-tail TH400 (so long as you don't mind that little missing piece of the bellhousing, anyway...).
These can be converted to TH400, but have to be completely disassembled to get down to the output shaft, which would have to be changed.
I'm interested in whether the driveshaft has been re-sized, or whether it is an original length, since it would be useful wo know which Camaro driveshaft will allow a longtail A-body trans swap.
Got it, I think it was labeled a 375.... Ed picked up a turbo 400 and driveshaft from a 71 Lemans here in So we have what we need. We can look the camaro shaft over to see any signs of shortening.... Ed is also looking to "dispose" of the 350. Looks to have been rebuilt...at least under the valve covers all the rockers look new and there is a performer intake and the 7a heads.
Well the 455 is in but it did not go as planned. (when does it ever?) Did not check new engine mounts Ed got from Summit. Lowered engine in and could not get mounts to pin, not really even close. After an hour or so we put the still good 350 mounts on and the engine dropped nicely in place except the left Flowtech header was resting on the frame and would not let that mount get bolted thru. After 3 beatings on 2 tubes the fit was there. There also was a slight interference at the block so some more hammer blows were required. Now if the starter bolts up all will be well. The brake junction block was relocated to top of the frame and new front lines were made because the old ones were poorly made and routed. We replaced the bailing wire holding the brake lines to the frame with proper clips and the wire holding the front rubber lines to their brackets as well. Bleeding is still required. Since there is not a lot of room to work the trans will be installed alone. Ed found a short tail Turbo 400 and driveshaft from a Lemans of the same year. Wider radiator mounts need to be fitted yet.... still work to be done!
Sounds like a bit of a tough job, but you're making good progress, and the worst seems to be over.
Also sounds like you found a well-matched transmission, which is at least a bit of a plus.
It'll feel great when she first starts up.
#32
I was hoping for some pictures of the chicken . Seriously looking good !See that Joe also took no rest after the Trac Pac project .
#33
Trans went in today and cross member. We mounted the new lower brackets for the 4 row radiator. The driveshaft is just an inch too long and there is at least that much on the yoke that is not splined so we need to cut some off. Lots of loose ends to tighten up but the heavy work is done!
#34
Ok, did not think the driveshaft thing thru... It is too long but since the yoke was ALL the way in trimming it will do nothing as it was not bottom-ing out. It is about 2 inches too long. So now the hunt is on for a shorter driveshaft. Maybe the non fit is due to the rear which appears to be a Chevy rear. Radiator is in with the new wider mounts installed top and bottom. Exhaust pipes ready to hook up to collectors as soon as some adaptors/couplings are had.
#35
Not sure why Joe is looking at the menu, he orders the same everytime!
#39
Thanks for the chicken pics - looks yummy! Those small hole in the wall places usually make some great food. I should have volunteered to help you guys out earlier in this chicken, errr engine, project .
