1967 442 Body Off Restoration
Old September 28th, 2011, 07:04 PM
  #41
Kjr442
kjr442's Avatar
Originally Posted by Chesrown 67 OAI
You are correct - Type P rears were used in the 67 W30 cars ( and all were the 4 pinion cone-type posi units too (no open rears were used --- all posis)(another disproof) == the axle tube code would be the key here. Once again --- this can only DISPROVE -- not Prove -- because of the interchangeability of the unit! Obviously if it has a correct W30 axle code then this cant be used to DISPROVE == are ya'all with me on this DISPROVE VS PROVE thing?
Ya'all ? Are you from the south? You know you're W30 cars, that's for sure!
kjr442 is offline
Old September 29th, 2011, 07:58 AM
  #42
1robert's Avatar
Actually it is in a 1967 442 (not W-30) with a 12E build code ordered with the G88 Heavy Duty Performance Axel 3.90 and G80 Anti-Spin Rear Axel. It is as it came from the factory - not changed.
I am with you on the "Disprove" versus "Prove" position.
1robert is offline
Old September 30th, 2011, 06:43 AM
  #43
Sea five's Avatar
I am with you on the disprove vs prove thing.It makes a lot of sence and great discussion.I now have a ton more info then before thank you.
Thanks to all for the great response.
Sea five is offline
Old September 30th, 2011, 06:47 AM
  #44
Sea five's Avatar
Well said Tweed, Sea Five you are making great progress, keep the pictures and reports coming!!
I will. How ever I will use my good camera
Sea five is offline
Old October 6th, 2011, 04:09 PM
  #45
Sea five's Avatar
Christmas in October. Santa came early ( Fed Ex driver)I received my disc brake kit from Summit. i was very impressed with the delivery time I placed my order at 1pm on Thursday afternoon and Santa was in my garage 9:30am Saturday.
Sea five is offline
Old October 6th, 2011, 04:50 PM
  #46
NOVICE car nut
oldsguybry's Avatar
great car , and no rust.... wow
oldsguybry is offline
Old October 6th, 2011, 04:59 PM
  #47
Sea five's Avatar
Thank you
Sea five is offline
Old October 6th, 2011, 05:23 PM
  #48
car guy
gearheads78's Avatar
pictures are much better
gearheads78 is offline
Old October 15th, 2011, 10:01 AM
  #49
Sea five's Avatar
Last weekend I fished removing ball joints control arm bushings ect. now i'm waiting for all the parts to be returned from the sand blaster.I decided to do some work on the IP.How ever I have a couple of questions. I've attach two photos one of the is of them radio cut out. I'm not sure if this dash has been cut or is the fm radio bigger than an am? The hole looks big to me.
The other photo show a fuse holder with a small 2amp fuse. The temp and oil pressure gauge didn't work could this fuse solve that problem. The tach and fuel gauge and amp meter worked fine
As alway thanks to all for the help
Sea five is offline
Old October 15th, 2011, 03:22 PM
  #50
Oldsmaniac's Avatar
Yes the dash looks like it is cut top and bottom a hair.....silver edge goes across bottom and top while yours looks to be missing. i am not familiar with the rally pac dash so i cant answer the fuse question....maybe the shop manual can and I only have a 66 edition.
Oldsmaniac is offline
Old October 15th, 2011, 03:33 PM
  #51
Sea five's Avatar
Thank you. Is there someone on CO that restores IPs
Sea five is offline
Old October 15th, 2011, 04:31 PM
  #52
OLDSMORAT's Avatar
There sure is his name is ron roth. Lives in rochester michigan. He's on oc. Just search dashboard chome and you will find him. He did my 67 442
ip and it looks better than factory. His is a great guy and loves his work. Check him out
OLDSMORAT is offline
Old October 15th, 2011, 06:33 PM
  #53
rroth01's Avatar
Location: Orion Township Michigan 30 Miles North of the Murder City
Thanks for the kind words Richard.Sea five.Someone has cut that dash probably to accomodate a stereo.I can restore an IP for you I have quite a few cores .That particular area is extremely difficult if not impossible to fill.As for the Rallye Pac.I am currently doing 2 restorations for Tweed Vorhees and the one IP has a Rallye Pac.I can take pictures of the gauge pack and send them to you for wiring purposes.Give me a call if you want to talk about a restoration.
Ron Roth
586-556-1234
rroth01 is offline
Old October 17th, 2011, 07:14 AM
  #54
this is not my car lol
scubastever's Avatar
Thumbs up
:thumbsup
scubastever is offline
Old October 19th, 2011, 08:37 AM
  #55
Sea five's Avatar
Ron Roth
586-556-1234
Thank you any pics would be a big help.
Also I will be calling you if I'm third or forth in line that's ok I'm a year away from reinstall.
Sea five is offline
Old October 24th, 2011, 06:29 PM
  #56
CLcutlass's Avatar
Originally Posted by Sea five
Inch by inch I was able to roll the frame from left to right. I had to secure the left side of the body. On the right side I move the jacks and blocks as needed in order to roll the frame out. Enjoy the photos and thanks for all the advice and interest.
Cool this will help me decide on how to get the body off....I was thinking a few buddies and a case of beer but that could get dangerous
CLcutlass is offline
Old October 24th, 2011, 07:00 PM
  #57
rroth01's Avatar
Instrument Panel Restoration
Jim
I have sent you the link.
To your EMail
If I am still alive in a year ,I am here for you.
Remember I live in Detroit.
Only joking..
I am here for you when you are ready
Good luck on the project.
Or as the say in Canada
The Pro Ject
Ron
586-556-1234
rroth01 is offline
Old October 26th, 2011, 03:14 PM
  #58
Sea five's Avatar
I attached some pics that might be helpful they show how I blocked the body. However there are a few things i would do differently.
1 4 good floor jacks. Not 1 good and 1 not so good like i had
2 A good friend that you can work well with. Not alone like I did
3 If you need hight use 4x4s on the floor to put the jacks on. Do pile 4x4's on the top of the jack the body becomes very unstable.
4 No beers until everything is stable.
Enjoy and good luck I'll be following your build
Sea five is offline
Old November 12th, 2011, 06:45 AM
  #59
Sea five's Avatar
Its time for an update I got some parts back from the sandblaster. Got most of them primed and paint ready.
Sea five is offline
Old November 20th, 2011, 10:18 AM
  #60
Sea five's Avatar
I'm still doing a lot of disassembly door glass, window regulators and a lot of little picky stuff.I forgot what a pain window regulators can be. But I did get the core support back from the body and it looks great IMO.It's nice to see parts ready for reassembly
Sea five is offline
Old November 20th, 2011, 10:42 AM
  #61
Kjr442
kjr442's Avatar
Things are looking up ,you are moving fast on this.
kjr442 is offline
Old November 24th, 2011, 07:29 AM
  #62
Sea five's Avatar
Thanks thing are moving very well. Unfortunately Our weather is moving well also right into winter I hope that doesn't slow down progress I,m looking to rent a garage for another car I have, If not the chassis build waits for the spring.That means body work all winter.
Sea five is offline
Old December 4th, 2011, 03:50 PM
  #63
Sea five's Avatar
I got some garage time this weekend made a lot of progress on the body got the firewall some what cleaned. i used a paint remover wheel on my 4 1/2in grinder worked pretty good.
Sea five is offline
Old December 4th, 2011, 03:55 PM
  #64
Sea five's Avatar
Some of the seam sealer was falling apart so I decided to remove all the seam sealer and clean up the floors a bit.
Sea five is offline
Old December 4th, 2011, 04:55 PM
  #65
car guy
wow that thing is solid
Old December 5th, 2011, 11:48 AM
  #66
Sea five's Avatar
Yes it is. I'm very pleased it looks like new seam sealer and POR15 and the floors are good to go !!!
Sea five is offline
Old December 24th, 2011, 10:11 AM
  #67
Sea five's Avatar
The last couple of weekends of garage time has not been glamorous. I've been cleaning the underside of the body. A lot of build up in 44 years many hrs of degreasing cleaning and last but not least undercoating removal. I used a torch to get the 44 year old undercoating soft then scraped it of.Still collecting chassis parts. This week rear brake parts arrived with the exception of the front e brake cable.
Sea five is offline
Old December 24th, 2011, 10:18 AM
  #68
Sea five's Avatar
One thing I learned on CO is everybody loves more pics
Sea five is offline
Old December 24th, 2011, 10:22 AM
  #69
Sea five's Avatar
Lower front control arms back from sandblasting,primed and ready for paint
Sea five is offline
Old December 25th, 2011, 04:09 PM
  #70
Tony
archeryshooter's Avatar
After the chassis tear down I've been doing a lot of cleaning removing old bushings and more cleaning. Some parts went to be blasted. Photos show fenders down to metal after blasting and primed
wow those are nice car looks clean
archeryshooter is offline
Old January 7th, 2012, 12:27 PM
  #71
Sea five's Avatar
I mad a little progress over the Holiday season. I tried my hand at spray painting. Other than a rattle can I have no experience. A friend has a body who is also working on my hood gave me a crash course 101 on paint mixing and spraying. Photos below show the end results not bad if I do say so myself.
Sea five is offline
Old January 7th, 2012, 12:34 PM
  #72
Sea five's Avatar
Below are photos of the hood repairs in progress.It's good to have a someone you feel comfortable with that is capable of making this kind of repairs
Sea five is offline
Old January 8th, 2012, 06:50 PM
  #73
Tony
ouch! tough spot to fix
Old January 8th, 2012, 07:11 PM
  #74
Kjr442
kjr442's Avatar
Smile
So this is the only rust you have found? As clean as this car is, I am surprised you even found this.
kjr442 is offline
Old January 25th, 2012, 11:57 AM
  #75
Sea five's Avatar
This is the most rust I've found but not all of it. i also found a little under the rear wheel well moulding when I removed them. I also have not removed the front or rear glass yet so time will tell but I'm still very happy about the minimal of rust
Sea five is offline
Old January 25th, 2012, 07:39 PM
  #76
Tony
sounds like you are making good time if there is no rust around the windows you got her made
Old February 18th, 2012, 05:51 AM
  #77
Sea five's Avatar
Well haven't reported much just finished removing undercoating nothing glamorous about that but I'm glade it's behind me.I sent my frame out to have some welding done on the rear cross bar looks like someone put a hook on it and pulled i out a little, not a big deal. From there to the sandblaster and that start the chassis build.
Sea five is offline
Old February 21st, 2012, 04:36 PM
  #78
Sea five's Avatar
Started to work on the diff this weekend. Found out I have 3:23 gears I am going to upgrade to a posi. I think the 3:23 are good all around gears I hope to do some long distance drives so I don't want the gearing to steep.Any thoughs always welcome.
Sea five is offline
Old February 21st, 2012, 04:46 PM
  #79
Oldsmaniac's Avatar
323 gears are a good all around gear..... usually it was the most GM liked to put in there on AC cars.... For me I would need at least 355's... ya would want a little ballzy feeling being it is a 442!
Old February 26th, 2012, 05:54 AM
  #80
Sea five's Avatar
Body work has begun. Thanks to a friend it was a very successful Saturday. The right rear quarter was the first to get a new life. Old rust was cut out and new metal fabricated and welded in place.The transition in just four hrs is amazing.
Sea five is offline
Quick Reply: 1967 442 Body Off Restoration
