young olds' 68 olds delta custom
Old August 4th, 2010, 05:04 AM
  #81
jaunty75's Avatar
Originally Posted by young olds
were did those post about the sending unit go anyways
were did all of the post from made in usa go, also wasnt this thread use to be 3 pages?
Good question. I don't know. Moved to another thread?
jaunty75 is offline
Old August 4th, 2010, 10:33 AM
  #82
young olds's Avatar
thats weird, do you remember/know the number for that sending unit?
young olds is online now
Old August 4th, 2010, 11:50 AM
  #83
jaunty75's Avatar
Yes. It's FG106A. You can order it from Rockauto.com. You can also likely find it at local auto parts stores, but you would probably have to order it at the store and wait a day or two for it to come in. As I recall, rockauto was cheaper, but you have to pay shipping. The local store might be more, but you pay only sales tax, and it's easier to return if you have an issue with it.
jaunty75 is offline
Old August 4th, 2010, 12:17 PM
  #84
Past Administrator
Oldsguy's Avatar
He deleted his posts, no explanation or reason given. Don't know why.....
Oldsguy is offline
Old August 4th, 2010, 02:05 PM
  #85
toro68's Avatar
I like that body style!
toro68 is offline
Old August 4th, 2010, 06:22 PM
  #86
young olds's Avatar
thanks, me too.
Old August 17th, 2010, 11:54 AM
  #87
young olds's Avatar
should i be getting new bearings for my rear axle and front hubs? and i was wondering if i should run a higher tire pressure than factory recomended 24psi since i have radials on?
Old August 17th, 2010, 12:43 PM
  #88
jaunty75's Avatar
In my experience, replacing the front wheel bearings is easy as you have to remove them, anyway, if you want to service the front (drum) brakes. I've never tried to replace the rear wheel bearings on a car and probably wouldn't want to do so unless I suspected a problem.
I run at 30 psi on the radials on my '67 Delta.
jaunty75 is offline
Old August 17th, 2010, 07:32 PM
  #89
young olds's Avatar
i have already had the front drums off so i know i can do that, i was just wondering about the back i dont want them to seize up on me and do something dumm. i was thinking about just going to 30psi cause 24psi seemed to little.
Old August 18th, 2010, 04:35 AM
  #90
jaunty75's Avatar
I've always never been quite sure what to do. Those recommended tire pressures that might be in the owner's manual or on a sticker in the glovebox are from back in the day when cars came with bias-ply tires. Tire manufacturers typically recommend 30-35 psi nowadays, in my experience, and that's what I've gone with for many years without a problem. I just judge it on the basis of handling and tire wear.
A consistently underinflated tire will show more wear along the outsides of the tread than down the middle, and an overinflated tire will show the opposite. If at, say, 30 psi, the wear is even and the car handles without a problem, I stick with that inflation pressure.
jaunty75 is offline
Old August 18th, 2010, 08:50 AM
  #91
young olds's Avatar
ok thanks
Old September 8th, 2010, 06:48 PM
  #92
young olds's Avatar
nothing is really new just putting some pictures up.
Old September 9th, 2010, 04:59 AM
  #93
jaunty75's Avatar
Hey, we love pictures. Never apologize for putting up pictures. Your car looks NICE.
jaunty75 is offline
Old September 9th, 2010, 09:05 AM
  #94
young olds's Avatar
thanks
Old September 9th, 2010, 11:16 AM
  #95
D Appeldorn's Avatar
what kind of scoop did you fit?
Is it the same hight as a aftermarket filter?
just curious, i know not original but looks cool.
Tought of it just to make a friend with a 10.000dollar engine jealous
D Appeldorn is offline
Old September 9th, 2010, 12:13 PM
  #96
Oldsdruid
rocketraider's Avatar
Who gots the Comet?
rocketraider is online now
Old September 9th, 2010, 03:07 PM
  #97
jeffreyalman's Avatar
looks great!
jeffreyalman is offline
Old September 9th, 2010, 05:01 PM
  #98
young olds's Avatar
its a mr gasket street scoop. i dont know ive never had it side by side with one but i would say its close. i had to put a air cleaner spacer under the scoop to get it to clear the distributor wich made it to high to shut the hood, why would anyone want to do that anyways though. it was just sitting on there, i drive with the original air cleaner on.
Old September 9th, 2010, 05:02 PM
  #99
young olds's Avatar
Who gots the Comet?
thats my friends car.
Old September 9th, 2010, 05:07 PM
  #100
young olds's Avatar
here are some more scoop fitment pictures. i took the pictures on my phone so i could send the to my friend with the comet, he wants one.
Old September 10th, 2010, 10:13 AM
  #101
Just for one day, just to see them wondering why i did that
as for the space, i run a performer intake with performer and aftermarket filter.
And noticed that there is not much space left.
Old September 10th, 2010, 06:47 PM
  #102
young olds's Avatar
ive got the stock intake and carb so im pretty sure it sits lower than yours
Old October 29th, 2010, 10:19 AM
  #103
young olds's Avatar
Since ive been having some problems with my engine running correctly and it having 117,876 miles on it i decided to replace the timing chain. And since it is just a stock engine i knew i didnt need a fancy timing chain, also i didnt have the money for one, so i got a cloyes factory replacement. Here are some pictures of my progress from yesterday, i hope to finish it today.
Old October 29th, 2010, 10:22 AM
  #104
The Cloyes is a good choice.
1969w3155 is offline
Old October 29th, 2010, 10:26 AM
  #105
young olds's Avatar
by the end of the day i had the front cover and water pump bolted on and the oil pan tightened up, and i can say that i never want to replace a timing chain while the engine is in the car again.
Old October 29th, 2010, 10:38 AM
  #106
Past Administrator
Oldsguy's Avatar
I agree, it isn't fun.
Oldsguy is offline
Old November 2nd, 2010, 10:37 AM
  #107
Oldsdruid
Yah, real PITA in the car, especially trying to get the front oil pan seal back in. Gotta give it to it though- the original timing set looked a lot better than most with that mileage. You lost only a little plastic. Every one I ever did, most of the nylon ended up in the pan.
A trick I learned from a Chevy guy (see they are good for something!). Take a grinder to the inside lip of the timing cover oil pan seal rail and trim away a little of it, making sure to leave enough to hold the seal in place. That way you don't have to fight with the oil pan to get the timing cover back in place, and makes it so much simpler the next time! I think Chevrolet actually made a production change on their timing covers.
Old February 23rd, 2011, 02:10 PM
  #108
young olds's Avatar
Just some pictures of the trunk light and electric trunk release i put on over the last couple of months.
Old February 23rd, 2011, 02:15 PM
  #109
young olds's Avatar
I also put in an expansion tank and some gauges. and added a shrunken head to my rear view mirror.
Old February 23rd, 2011, 02:18 PM
  #110
young olds's Avatar
These pictures are from ealier today.
Old February 23rd, 2011, 02:19 PM
  #111
toro68's Avatar
Nice Detla!
I like 1968 Oldsmobiles too!
toro68 is offline
Old February 23rd, 2011, 02:25 PM
  #112
young olds's Avatar
Old September 6th, 2011, 02:40 PM
  #113
young olds's Avatar
I have spent the last couple days cleaning up my car. I washed and waxed it, polished the chrome, cleaned the windows and vacuumed the interior and trunk.
Old September 6th, 2011, 02:49 PM
  #114
young olds's Avatar
Since I got my 62 I finally decided what I want to do with the delta. Its gonna be my dedicated daily driver, I am gonna do a "restoration while im driving it" style of restoration and keep it mostly stock. I did put in a center console with alpine radio and I built some sub boxes to fit in the trunk. I am also going to add some options to the car, so far I've added a trunk light and trunk release, I also have an electric antenna and a rear defroster for it.
Old September 6th, 2011, 02:52 PM
  #115
jaunty75's Avatar
I have a set of '67 Delta 88 wheelcovers. You want 'em? You can have them for the cost of shipping. They're 14-inch. I don't know if that was still the standard wheel size for 1968.
They're the ones you see in this photo.
jaunty75 is offline
Old September 6th, 2011, 03:52 PM
  #116
young olds's Avatar
Thanks for the offer but im just gonna get toro center caps for my wheels, they are 15".
Old November 10th, 2011, 01:30 PM
  #117
young olds's Avatar
My engine is leaking oil really bad so I got a gasket set. I also took my heads in to a machine shop and had them checked. They ended up having loose vavle guides. So I had them do a valve job, put new guides in and reserfice the exhaust side and combustion chamber side, I bought new valve springs and rocker arms for them too. I brought the heads home today and put the new valve stem seals and springs on, I still have to pull the engine and put the new gaskets in and paint it.
Old November 26th, 2011, 10:28 PM
  #118
young olds's Avatar
I tore my engine down the other day, found out my engine has a forged crank, and cleaned it up today. I also put in the new lifters and rocker arms. Sorry for the bad pictures, the last one is the only one from after the cleaning.
Old November 27th, 2011, 04:16 AM
  #119
jaunty75's Avatar
Looks good!
jaunty75 is offline
Old November 29th, 2011, 11:34 PM
  #120
young olds's Avatar
painted engine
I got my engine all painted and should be dropping it back in the car tomarrow.
Quick Reply: young olds' 68 olds delta custom
