71 Vista Cruiser Resto....
Finally picked up the frame and small parts from the powdercoater yesterday. I'm excited that I am actually getting somewhere lol. I've been stock pilling parts for a couple of years. I've been very lucky with finding parts. I'm going to post more pics if people are interested.
Huh???? That's a no brainer. We LOVE pictures of projects
The original owner had a bodyshop with his son. He started the work and removed the miles and miles of trim. I have it all. The guy called me back 4 times to give me more parts that he found.
It is a 350 2bbl and a 2 seat wagon. I am going to have the engine rebuilt to 325hp specs but keeping it as stock as possible. 10 bolt 3:31 rear and th350 trans.
Interesting. Your 71 has a 72 Radiator support. Not that it will affect your build, those raised areas were to accommodate the 72 grills being forward in the stone shield. It suggests this car has had previous front end damage.
Wow, thanks for the info. You know it makes perfect sense. The grills and the stone guard were out of the car when i got it and were both pretty damaged. I also noticed that the battery tray was missing as well. Im not going to use that core supoort anyway due to major rot on the lower part. They used this car to tow a popup trailer and it had two batteries in it. Im trying to find out if the car came with a tow package or if all the options were added i.e. (wire harness, hitch, brake controller and extra battery. Still haven't found a build sheet.
nice another jersey Guy!
Nice job on the frame looking forward to your build, and your in Edison, Im just down the road near East Brunswick ( exit 9 LOL) I'll be following along and if I can help with Anything let me know.
eddie
eddie
You won't find a build sheet then. Lansing was fastidious about removing them when the car hit the end of the final assembly line. What you might find instead is called a broadcast card. It was left in the body shell by Fisher Body Works (the plant that built the body and installed the interior of the car). Typically the broadcast card will confirm the body number on the cowl tag, and some of the options that were installed in the car. It's not related to the VIN though. Looks like this, from a 2 seat Vista Cruiser (1972):
The air cleaner on that engine looks like it's hiding a 4bbl carb. The 2 bbl air cleaner is very distinctive; it's taller and has a different lid and snorkel. Also, just based on the color of the valve covers it suggests the engine is a 455 instead of a 350. How to tell the difference is really simple. Check the engine casting number (right beside the oil sender). If it's 395558-2 it's a 350. If on the other hand it's 396021 F it's a 455. You can also look at the heads. 350 heads will have a 7 by the #1 cylinder whereas the 455 will have a G
references for you if you're not sure about these castings
Heres where the engine block casting will be:
Here's where the head casting will be (the one shown is 1972 350 which also has a small A):
If the car still has the original drive train it will also have a matching TH400 Transmission. Easy to tell on the engine and transmission as they will have a VIN derivative on the engine block and left side of the transmission. It would start out 30M (Olds,1970, Michigan) and the last 6 numbers would be the last 6 numbers on the cars VIN.
Oh, that motor in that pic is a 77 350 4bbl. Thays not the original motor. The owners ran the original 350 2bbl without oil to the top end and locking up the motor. I have that motor in my garage. 31M407517. It matches the vin number perfectly. BTW that 77 350 in the pic is for sale, if you know anyone that needs a 77 350. Sorry for the confusion.
Just curiosity, but with a VIN that high I'm wondering if your VC was produced in June of 71.
Another tidbit of Information you might already know, but VC production in 1971 wasn't really high. The 2 seat models were only 9317 production, while the 3 seat (which nobody seems to be able to find now) was up at 20,566
Took the spindles assembly apart and cleaned it all in the parts washer. I found this green paint. I know why its there just not sure if i should put it back after sandblasting. I wanted to paint them with cast paint so they don't rust. Should I reproduce it after? I haven't found any other markings like this on any other part.
I put it back on mine after painting it with cast. Didn't get quite the same color but that's ok. Your call whether you want it or not, but since you're trying to keep it as stock as possible, a bit more paint on top of the cast won't hurt the protection factor, and will add to the authenticity of the restoration. I doubt anyone will notice it though unless you're going for points at a judging?
Your figure for the two-seat model production is 55% higher than the figure I am accustomed to seeing. Not saying your source is wrong; just pointing out an oddity. Your three-seat model production number is within 10 units of other sources.
They are considered to be extremely accurate.
#32
Removed the glass
I removed the glass and found most of the channels are good. Some areas need a good amount of attention. Previous owner had all these removed before. Didn't do a good job since all of them were loose. Let the fabrication begin !!!!
auto_editor
Vista Cruiser & Wagons
February 6th, 2011 08:34 AM
