1967 442 rebuild
Old December 30th, 2018, 02:44 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
1967 442 rebuild
Video of car idling. Have a Holley ultra xp 950 and Edelbrock Air-Gap to install.
I rebuilt this many moons ago. Never had a video till now. Car now has 3.90 gears and ladder bars.
67Olds442X2 is offline
Old December 30th, 2018, 06:12 PM
2blu442's Avatar
Nice! Looks like a fun toy!
2blu442 is offline
Old January 1st, 2019, 07:15 AM
Navy P-3 FE (Ret.)
Yes it is,
455 .030 over Stock crank Eagle "H" beam rods Probe flat top pistons approx 11.95 to 1 comp ratio Lunati solid cam 285/295 252/261 @.050, .560/.560 lift (.595/.595 with rockers) Harland Sharp 1:7 to 1 roller rockers Comp Cams hardened push rods. Edelbrock heads with Edelbrock valves and Lunati bee-hive springs Edelbrock torker in video but currently has an E-Brock Air Gap intake. Carter 750 in video but currently gas a 950 Holley Ultra XP carburetor. MSD ignition Hooker Headers 3000 stall Hughes converter. Transmission rebuilt with Hughes bands , clutches and valve body etc. Hurst pistol grip quarter stick shifter. "O" rear rebuilt with an anti-spin carrier and 3.90 gears from Supercars Unlimited. Premium axle shafts from Same. Summit racing tubular suspension front, QA1 version rear. Right Stuff complete disc brake conversion kit. Pipes 3" exhaust into Thrush mufflers. Has Lakewood ladder bars installed currently. Infinity 6x8 front speakers Infinity 6x9 rear speakers Infinity 100 watt amp and 100 watt sub amp. two Infinity 10" woofers in trunk.
Old January 1st, 2019, 07:25 AM
72 Olds CS
RetroRanger's Avatar
Sounds healthy. Any estimate on torque or hp? What about the hood? scoop? Or another hood?
RetroRanger is offline
Old January 1st, 2019, 01:11 PM
Wow, sounds great. I thought you sold it last year. What happened to the ladder bars?
oldcutlass is online now
Old January 1st, 2019, 10:17 PM
Navy P-3 FE (Ret.)
No estimate on torque or HP. Put a cowl scoop on. This is my third build, dual quads , Tunnel Ram now this . Valves covers are loose because I released the spring pressure for the solid lifters.
Funny the hood has been modified three times, for Dual Quads with spacer, Tunnel Ram and now the cowl. I've had it out many times the way it is setup now but forgot the video. It's much more alive, almost scary, with the 3.90 vice the original 3.08 gears.
Old January 1st, 2019, 11:27 PM
Navy P-3 FE (Ret.)
I do have it posted for sale on here. But I got the dash apart again. Ladders bars installed.
Old January 1st, 2019, 11:30 PM
Navy P-3 FE (Ret.)
Holley Ultra XP 950 and Edelbrock Air-Gap.
Old January 1st, 2019, 11:43 PM
Navy P-3 FE (Ret.)
First build.
Second
67Olds442X2
May 6th, 2019 01:06 AM
coppercutlass
March 9th, 2018 12:52 PM
67Olds442X2
July 12th, 2016 05:15 PM
815Cutlass1972
November 13th, 2013 07:39 PM
67Olds442X2
April 19th, 2011 07:52 PM
Quick Reply: 1967 442 rebuild
