Column mounted tach question...
Old December 22nd, 2018, 07:43 AM
Hey all!😀. I hope everyone is doing well. When I swapped out the gauges in my 72 Supreme, I mounted my aftermarket tach to the steering column. Because of the where the lock cylinder is and the hazard flasher button, there's not a lot of room. My fix was black plastic zip ties, and while they get the job done, they're not the most aesthetic solution. I've tried the metal strap zip ties, but they won't draw up tight enough. Does anyone have any suggestions?
Thanks, and Merry Christmas!
Dave
72455 is offline
Old December 22nd, 2018, 08:28 AM
Use a large stainless hose clamp or if you don't like the bling paint it black. Another option is too put it by the A pillar that way you can see your guages
w30442 is offline
Old December 22nd, 2018, 09:16 AM
Thanks for the suggestion, but a hose clamp is too wide.
72455 is offline
Old December 22nd, 2018, 12:26 PM
Inline's Avatar
I used metal zip-ties and got them tight enough. Theres special tool for getting them tight, but good side-cutters will do. Mines mounted to column too.
Inline is online now
Old December 22nd, 2018, 01:13 PM
A hose clamp will work just fine IF you cut/file clearance "notches" into the clamp where it's near those interference items...I've done this on a clamp while mocking up things for an old Sun tach I want to run on the column. The clamp is on the first "column sleeve"/cover ...the cover just in front of the steering wheel hub. Puts the front edge of the tach fairly close to the steering wheel but it doesn't interfere with your fingers, etc on the wheel.
EDIT/ADD: Oh yeah....Merry Christmas and have a great 2019.
70Post is offline
Old December 22nd, 2018, 02:13 PM
And you can slip black heat shrink tubing over the clamp strap to pretty it up.
oldcutlass is online now
Old December 22nd, 2018, 02:42 PM
72 Olds CS
RetroRanger's Avatar
you could mount the tach in the clock hole in the dash
RetroRanger is offline
Old December 22nd, 2018, 03:30 PM
Dave
Are you saying you swapped out your U21 Rallye Pac option? (tic toc tach side?)
Allan R is online now
Old December 22nd, 2018, 06:42 PM
Goodness gracious no Allan😵 I wouldn't commit such a heinous crime...lol. If you recall, when I bought my Cutlass and posted my intro here on the board, the pics show a huge (and rather unsightly) guage pod that was "hung" in front of the ashtray. I got rid of that and put a triple guage set under the dash, rebuilt the ashtray area, and mounted a tach to my steering column. Sadly, my car wasn't equipped with the tic-toc-tach, just the clock.
72455 is offline
442crzy
August 10th, 2018 02:48 PM
joesw31
May 20th, 2018 01:28 PM
70Post
March 26th, 2017 02:30 PM
Wood
October 2nd, 2016 08:41 AM
66cv442
May 26th, 2009 05:47 PM
Quick Reply: Column mounted tach question...
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
