Door hinge issue...
Old September 27th, 2018, 01:57 AM
72455's Avatar
Door hinge issue...
Greetings to all ye Oldsmobilers! I have a slight issue with the driver's side door hinge on my 72 Cutlass Supreme. (See pic below). The door opens and closes with no issues and it doesn't sag, but I don't want it to become a bigger problem. Can it be fixed without removing the door?
72455 is offline
Old September 27th, 2018, 04:45 AM
Army_Vet's Avatar
You should be able to support the door and replace the upper hinge.
Army_Vet is offline
Old September 27th, 2018, 01:31 PM
OLDSter Ralph's Avatar
You are definitely missing the bushing in the upper hinge. I would also look at the lower hinge, I am sure the bushing is badly worn and needs replacement.
OLDSter Ralph is offline
Old September 27th, 2018, 02:46 PM
v8al's Avatar
Keep in mind that door hinge replacement can spiral into having to remove the front fender. If the alignment isn't right on the body side hinge mounts the only way to adjust with the door on is to remove the fender.
Also, I'd recommend putting some tape on the door / fender edges and bottom of door to try to prevent paint chips. Try to wrap the tape around the front and back side of the metal.
v8al is offline
Old September 27th, 2018, 03:40 PM
Dave, you can buy a door hinge repair kit for less than $10.00 and do the pin/bushing replacement yourself. Otherwise the whole assembly costs around 75.00
As noted, you can support the door and remove the hinge. The fix takes a bit of trial and error, and you'd be best to have a friend help with the process.
Allan R is offline
Old September 27th, 2018, 06:25 PM
ragz442's Avatar
That's actually not the pin bushing, it's the roller and is normally not serviced. You need to replace the hinge. I have been able to repair these in the past but it takes a little ingenuity.
ragz442 is offline
Old September 27th, 2018, 07:19 PM
72 Olds CS
RetroRanger's Avatar
get a good used hinge and rebuild it then swap it in, the repop hinges require repop parts to repair the GM hinges can be repaired w GM parts
RetroRanger is offline
Old September 27th, 2018, 08:03 PM
72455's Avatar
Thanks for all the input everybody. Why can't I just pry back on the part that rides on the collar and drop in a new bushing?
72455 is offline
Old September 28th, 2018, 02:49 AM
ragz442's Avatar
You can do what ever it takes, but it is not a bushing. It's a roller and it is pressed/staked on to that pin. That is not the pin that the bushings go bad in. Look at the passengers side (it is probably ok) and you will see what it does. The last upper I rebuilt with a bad roller I did what Retro Ranger suggested and got lucky and found a used hinge w/a good roller and replaced the pins and bushings. They sell a spring compressor (cheap) which I recommend for removing/installing the spring. I have replaced/retro fit new rollers on the hinge before, but it has been so long ago I can't give you any details.
ragz442 is offline
Body work
September 26th, 2018 10:32 AM
Bfg
August 13th, 2014 05:17 PM
Mred355
December 22nd, 2013 07:33 PM
chucho
March 13th, 2012 09:14 AM
veltboy618
July 26th, 2010 07:15 PM
Quick Reply: Door hinge issue...
