1973 oldsmobile revcon
Old August 27th, 2018, 06:58 AM
Talking 1973 oldsmobile revcon
I am astounded that i came across this treasure and hope that with the help of you all, i can restore it to its former glory.
Also, its got the 455 rocket and ive got it to run and it is smooooooth
I suppose that we should begin at the most pressing matter, there is no brake booster. I have tried the 1973 olds toronado booster and its arm is more than half a foot too short and the bolt holes dont match up. Anyone know where i can find this thing? It appears that this is an issue with these revcons, finding parts.
Goodoldsreliable is offline
Old August 27th, 2018, 07:14 AM
Proud Viet Nam Veteran
redoldsman's Avatar
It would help is we knew what the car is. Is it a Cutlass, 442, Delta 88 or a 98? It should not be a problem finding a booster.
redoldsman is offline
Old August 27th, 2018, 08:00 AM
It is a 1973 Oldsmobile Revcon 250
Old August 27th, 2018, 09:06 AM
same but different
don71's Avatar
Ok, so revcon is a motor home using the toranado drive train. The stepson of the airstream guy invented this lineup of motor home. I came across this old link listing some suppliers and owners.
http://www.policeinterceptor.com/revconlinks.htm
I'm going to guess this vehicle uses some custom and propriety parts. The booster is probably the easy one, but the rod a little more challenging to find. Hope someone can be of help to you, there is going to be some homework on this one.
don71 is offline
Old August 27th, 2018, 09:21 AM
redoldsman's Avatar
I remember the motor homes and always thought they were cool. I guess I would never have considered them an Oldsmobile although they were Oldsmobile powered. Good luck with your search.
Old August 27th, 2018, 01:57 PM
Well i do happen to have the rod still, is there a good chance i can get one that bolts up and use the old arm? Are these brake boosters relatively possible to rebuild?
Old August 27th, 2018, 01:58 PM
Also i do believe this beauty only has around 40k original miles
jaunty75
Vista Cruiser & Wagons
October 4th, 2014 05:21 PM
starr88
July 22nd, 2011 05:46 PM
73toro
April 19th, 2011 06:36 PM
<73hardtofindhurst>
December 11th, 2004 12:10 PM
Quick Reply: 1973 oldsmobile revcon
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
