1972 Cutlass S rebuild Suggestions
I have a 72 Cutlass that I’m having trouble deciding what to do with. I’ve thought about cloning it to a 442 and if I did that I would like it to have a 455. Trouble is that I find it extremely difficult to find a 455 that isn’t in another car and I don’t want/need 2 projects. My car currently has the original 350 it came with, and I’m leaning towards just having that rebuilt. I’m curious what you all think?
Spend a little extra now and get a 455. No replacement for displacement. Any 455 would be good does't matter what model it came from originally if your going to rebuild it. I would look for something with C E G or Ga heads and avoid the J. D F and H would be nice too but seeing as they are w30 heads probably not likely.
Not all engines are created equal. Just because they are all 455s doesn’t mean they all produce the same hp/torque. The cylinder walls may be thinner on some, and parts/mounts will be in different locations.
In that regard, Olds made it easy. All 455's had the same bones, Whether its from a Cutlass, 442 or F/S they all have the same basic block. Like a previous poster opined, J heads are considered worse for a performance build but they can be worked with depending on your goals. Plenty of guys run them on healthy street engines. Re brackets/pulleys/pumps etc all that stuff transfers from your current 350 to a 455,
From our Tech editor and VERY knowledgeable Olds expert who has addressed this issue so many times in the past I'm sure he's sick of it....
Every single Olds V8 from 1964-1990 is dimensionally identical externally except for the deck height differences from small block to big block. Motor mount holes, crank centerline, and bellhousing bolt pattern are all exactly the same on every single one.
__________________
Joe Padavano
__________________
Joe Padavano
Hercules
November 18th, 2013 01:07 PM
