1969 Cutlass Floor Replacement
Old June 30th, 2018, 04:59 AM
armycav0's Avatar
I am restoring a 69 Cutlass 442 and have to replace the passenger floor and the braces under it. Is there anyone here that has tips and/or pics of how they did theirs? I will be doing this on a rotisserie and the rocker panels are good on the body I have. Thanks in advance.
armycav0 is offline
Old June 30th, 2018, 06:54 AM
72 Olds CS
RetroRanger's Avatar
I did my floors ( first time) I used an air saw which I thought was pretty efficient. I started w a thin blade on a cutoff wheel but I found the air saw easier to use and much cleaner.
On the passenger side I trimmed the replacement panel and screwed it to the existing floor and then cut both parts together that worked pretty good. A couple spots were not as perfect a fit and I used a copper spoon on the backside while welding to prevent burnthru
When I was done I used seam sealer to cover the welds I then painted the pans.
I was happy w the end result but don't have any other similar work to compare to.
RetroRanger is offline
Old July 1st, 2018, 06:13 AM
therobski's Avatar
Here's a few pictures of what I did on my 64 F-85 Pro Touring build. Your fortunate to have the rotisserie, in order to replace one of those braces the body has to come off. As you can see I replaced everything including the trunk pans and braces. You will need to remove the spot welds on the drivers side floor to get the braces off- I don't think you want to cut the bad part of the brace off and weld to two back together, good question.
therobski is offline
Old July 4th, 2018, 01:02 PM
seanm12's Avatar
Floor braces and driver side floor on a 67
Here's a slideshow where took the floor out, worked on the braces, and replaced the driver side floor - http://mcewan.rocks/cutlass_stuff/20...oor/index.html
There are a lot of pictures in this. I painted the bottom of the floor before welding it in.
The parts I used are for 64-67 so therobski and I have similar parts. There are probably a few minor differences to a 69. The floor braces are spot welded in 4 places to the rocker. I was able to get to the bottom ones with a spot weld drill bit, but used a round ball carbide bit to grind off the top spot welds in order to get the floor braces off.
I found rust under the inner rockers where the brace welds in. That was either 16 or 18 gauge and a pretty simple place to make 1 bend in a flat piece of steel. The inner rocker was galvanized on my car, so be prepared for that if you need to patch the inner rocker.
seanm12 is offline
seanm12
Body work
June 30th, 2016 02:36 PM
Mike Sundy
July 6th, 2015 07:10 PM
Hawghead
Body work
38
September 8th, 2014 01:10 PM
Racer24ksi
July 21st, 2014 04:27 AM
RonFX
Body work
January 27th, 2014 03:40 PM
Quick Reply: 1969 Cutlass Floor Replacement
