Over heating issue
Old June 6th, 2018, 08:26 PM
richeyb's Avatar
Over heating issue
Finished brake job and took my 72 olds cutlass 350 for a quick spin to set and test the Brakes.. traveled about a mile and returned to barn and radiator was over heating and flowing out the reserve bottle...boiling out most of the antifreeze.
It has a new radiator, radiator cap and a shroud....
Any ideas?
richeyb is offline
Old June 6th, 2018, 09:01 PM
Is the light coming on? Are you filling the radiator to the top of to the fill level shown on the rear of the radiator, passenger side. Usually about 1 1/2 inches of head space. Or, Did you buy an overflow tank and cap that allows coolant to move in and out of the radiator as the coolant expands and contracts?
oldcutlass is online now
Old June 6th, 2018, 11:20 PM
Hookers under Hood
76olds's Avatar
Who installed the rad ? Was the t-stat replaced? Did it overheat prior to installing the new rad? Could be a head gasket at this point , more info needed as Oldcutlass suggests above.
Eric
76olds is offline
Old June 7th, 2018, 07:44 AM
richeyb's Avatar
Over heating
No light, filling to top, have not changed Thermostat, not sure on cap, ask for one for 72 cutlas.... my overflow is a homemade out of an old antifreeze jug, just to catch overflow.. never heard of head space for radiators?
Next step is change out thermostat, maybe light sensor too.
During my first test run a couple months ago I notice steam coming out seam in side of old radiator... Took it to be repaired and they said it was beyond repair so I bought new one and replaced... finally finished brake job and this is my result.
richeyb is offline
Old June 7th, 2018, 07:57 AM
What brand - pn radiator did you buy? Yes water expands as it heats up, it should only by filled about 1/2 - 1 inch over the trans cooler looking down into the radiator. You are in the never ending cycle of overfilling and then having the radiator puke the excess out the overflow.
The temp sensor is at the front of the engine, with the key on you can test the wiring by removing the wire and touching it to ground, the light will come on. I prefer a mechanical temp gauge to monitor at all times. In addition I like a mechanical oil pressure gauge, and a volt meter.
Old June 7th, 2018, 11:58 AM
richeyb's Avatar
OldCutlass it’s a Duralast radiator from Autozone Auto Parts. I’ll check out the sensor first chance I get.
richeyb is offline
Old June 7th, 2018, 12:35 PM
Aluminum with plastic tank? How many core is it?
https://www.autozone.com/cooling-hea...eVehicle=false
FatSparky
June 29th, 2019 07:21 AM
NotDads442
May 3rd, 2019 05:42 PM
Toronado76
August 9th, 2017 04:55 PM
72hardtop
May 21st, 2015 05:42 AM
plonka
December 12th, 2013 10:38 AM
Quick Reply: Over heating issue
