Lack of Horsepower in 350 Rocket
So I've been building my car for the past 10 years and recently got to the point of driving it. The car has: a Performer RPM Intake 7111 and the Lunati Voodoo Hydraulic Flat Tappet Cam 262/268. Currently the car has number 8 heads that have been worked and the stall being ran is 2400. I recently installed my 3.42 geared positive traction rear end. I'm barely able to get the tires to squeal when I floor it. I've checked my timing and it's spot on. What other things should I begin to trouble shoot?
Overall, I'm just trying to narrow some things down before I throw the towel in and send it to a shop...thank you guys...
I looked up the cam specs and got the following. Not extremely different than the cam in my 350 engine.
Some things we'll need in order to help you troubleshoot:
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 219/227
Gross Valve Lift (Int/Exh): .499/.510
LSA/ICL: 112/108
LSA/ICL: 112/108
- Was the camshaft degreed when it was installed?
- What type of pistons do you have - flat top or dished?
- If dished, what is the dish volume?
- What type of distributor do you have?
- What are the initial timing and total timing settings?
- What size rear tires does your car have?
Two things I would check on, first is do a compression test on each cylinder and the second is go over the fuel delivery system. Make sure the filter in your sending unit isn't clogged, fuel filters in-line aren't clogged, the fuel pump is operating properly, your carb is jetted properly, the float is seated properly and the accelerator pump is working (I am assuming you have a four-barrel carb rather than some multi-carb set up). If all of your cylinders are firing it sounds like it could be a fuel delivery issue. Good luck
Zrzoun
July 28th, 2015 11:59 AM
