Summer Goal - First Startup
Old June 18th, 2017, 12:16 PM
gbledsoe3's Avatar
It's been a long term project (10+ years), but once kids (4) were out of college and no longer living at home, we're able to move at a quicker pace with more funds available.
My goal this summer is to get engine assembled, everything bought and mocked up in the body necessary to start the engine. This includes trunk mounted battery utilizing info and supplies by Mark from MAD Enterprises, fuel system (tank, fuel lines, filters, regulator, etc) all mounted on the shaved firewall, motor between the rails, all accessories (a/c compressor, alternator, p/s pump) installed with their respective v-belts, radiator installed, dual spa fan relays wired and wiring harness with minimal circuits needed (ignition, fans, efi, fuel pump).
For fuel induction, I'll be using Holley Terminator EFI. I plan to use an analog water temp gauge and an analog oil pressure gauge for initial startup.
Questions:
Do I need to install a temporary tach for startup?
Are the analog water and oil pressure gauges ok?
The engine will be mated with a Tremec T-56 Magnum, do I need to install the clutch and get the hydraulic release bearing functional?
I don't plan on buying and installing a driveshaft yet, is that ok?
Do I need to get the brakes functional? E-brake is functional.
Eventually I will buy and use push button start by Advanced Keys, but will just use a cheap key set.
Do I need a functioning PCV system for this initial startup? Eventually, I'll be using a fully functional one with a PCV catch can from MightyMouse Solutions.
I appreciate any comments or suggestions you have to offer.
gbledsoe3 is offline
Old June 18th, 2017, 03:34 PM
Originally Posted by gbledsoe3
Questions:
I would, because you need to break in the cam.
They work great.
If your trans is installed so will the clutch. You at least need to install a spring to keep the throwout bearing from riding on the pressure plate.
Not a problem, just make sure the trans is in neutral and at least install a yoke.
No, wheel chocks work great.
Yes, I would run a PCV because you will have blowby initially until the rings seat.
oldcutlass is online now
Old June 18th, 2017, 04:10 PM
gbledsoe3's Avatar
it is a hydraulic roller cam and I understood no break-in is required.
Old June 18th, 2017, 04:12 PM
Then not necessary.
Old June 18th, 2017, 04:26 PM
gbledsoe3's Avatar
Then not necessary.
Thanks for the suggestions though. Forgot about installing at least a yoke in th transmission.
Old December 17th, 2017, 08:13 PM
gbledsoe3's Avatar
The minimal wiring is nearly complete. I added constant +12v and ignition switched +12v fuse panels under the dash. The main fuse panel is in the trunk. I mounted the Dakota Digital VHX gauge control box, connected to power and ground and wired in the water temperature, oil pressure and speed sensors. Moment of truth, turned key to ‘on’ position and ‘tad-a’, gauges powered up. Obviously, I left the gauges in their shipping box, as you can see.
We’re getting closer to getting the engine in and ready for the first ever startup. My goal was before year end - it’s going to be close.
Old December 18th, 2017, 03:13 AM
Progress, looks good.
80 Rocket
June 10th, 2015 09:58 AM
costpenn
October 13th, 2014 01:14 AM
gbody 442
January 5th, 2014 12:56 PM
skryla
Suspension & Handling
May 24th, 2010 04:54 PM
case2273
July 15th, 2009 02:00 PM
Quick Reply: Summer Goal - First Startup
