1970 Cutlass S Restoration Project
Old March 2nd, 2017, 11:17 AM
blackdog6124's Avatar
I recently finished my restoration project, and since I learned a lot of information from all of you on this forum, I thought I would share my experience.
This was my first attempt at restoring a classic car, so I was a little uncertain that I could pull off a project of this magnitude. I accomplished all the mechanical and
body work myself, with the exception of machine shop work and final paint/clear spraying. For those of you out there wondering if you could do the same, trust me, it can be
done. With quite a bit of research, gathering the right tools and materials and a little help from my friends, I was able to complete it. For those of you considering it,
some words of advice:
Be patient and don't rush things. I was able to complete this in a little over 2 years only working on it about 1-2 hours a day, mostly weekdays after work.
Get the right tools for the job, makes all the difference in the world.
Tunes and a beer refrigerator in the garage are a must have.
Being divorced helped. At one point, every room in my house including my screen porch had car parts in them. I know my ex definitely would not of put up with that...
My story:
In October 2014 I purchased a 1970 Cutlass S that was in pretty bad shape. It had the typical GM A body rust damage, collision damage in several places, surface rust, needed
a new interior, and had a BBC 454 engine that was poorly installed and needed to be completely rebuilt. It was partially dismantled but it had almost all of the trim parts,
and anything else that was removed.
After I got into it I discovered that the cowling, top of the windshield sheet metal and rear window sheet metal were completely rusted out. I had to fabricate replacement
parts and teach myself how to weld sheet metal after borrowing a friends MIG welder. I did all the body work myself and the primer/prep work for painting. I then learned how
to wet sand and do the final polishing.
While I had the engine, transmission out and the front clip removed, I did a front disk brake conversion replaced all of the brake lines and replaced all of the front
suspension bushings with Polyurethane. I also did the rear suspension, and added a rear sway bar.
Engine was completely rebuilt with new crankshaft, cam, lifters, push rods, oil pump, fuel pump, water pump, ignition system and carburetor. I also completely rewired it when
I had it out.
Interior was pretty much redone with new carpet, headliner, and seats reupholstered. The only things repairable were the dash pad and the door panels. First time I had tried
upholstering anything, I'm surprised how easy it was.
Here are some before, during and after pictures.
blackdog6124 is offline
Old March 2nd, 2017, 11:27 AM
TripDeuces's Avatar
Beautiful car and color.
TripDeuces is offline
Old March 2nd, 2017, 11:29 AM
Magna86's Avatar
Wow great job! Car looks amazing love the color!
Magna86 is offline
Old March 2nd, 2017, 11:37 AM
Thanks! It a new 2015 GM color. Butte red metallic.
Old March 3rd, 2017, 06:01 AM
costpenn's Avatar
Very, very cool color combination. Great work bringing back a wounded Rocket.
costpenn is offline
Old March 6th, 2017, 08:55 AM
Here are some before, during and after shots of the cowling...
Old March 6th, 2017, 11:16 AM
35tac's Avatar
Very nice job. Nice color choice.
Wayne
35tac is offline
Old March 6th, 2017, 12:17 PM
Thanks! I get a lot of comments about the color, I'm glad I went with the one I did.
Old March 6th, 2017, 06:56 PM
Stefano's Avatar
Very nice congrats!
Stefano is offline
Old March 7th, 2017, 05:48 AM
Rocketowner's Avatar
Exceptional work and x2 on the color choice. Larry
Rocketowner is offline
Old March 7th, 2017, 10:02 AM
Some shots of the engine..
Pre-purchase
Getting started..
Things are much easier with no front clip!!
Getting ready to pull it..
It was in really bad shape..
Almost ready to go back in..
Back to life!!
700 - 800 miles and still running strong..
Old March 8th, 2017, 11:34 AM
Some pics of the interior..
Pre-Sale..
Had to re-seal all the seams.
Out with the headliner.
Por 15 everywhere.
Insulated as much as I could.
In with the new.
Rear seat in.
Back deck with hidden speakers
Almost done.
Done!
Old March 8th, 2017, 06:27 PM
jemills27's Avatar
Wow great work, and awesome pictures!
jemills27 is offline
Old March 9th, 2017, 05:35 AM
Thanks! I'll add more as I sort through them all...
Old March 9th, 2017, 12:47 PM
same but different
don71's Avatar
Wow you came a long way with all the work. Looks great! Enjoy.
don71 is offline
Old March 10th, 2017, 05:43 AM
Thanks! I had a great time doing it...
70 w-30
January 5th, 2021 03:47 PM
Del70
July 21st, 2020 11:42 AM
Johnd
October 18th, 2015 06:52 AM
My72Cutlass
June 14th, 2013 09:34 AM
65culassholiday
July 9th, 2006 11:36 AM
Quick Reply: 1970 Cutlass S Restoration Project
