Rotisserie Help
Old August 22nd, 2016, 03:51 PM
TripDeuces's Avatar
Rotisserie Help
I bought a rotisserie and it's now bolted to the body and ready to twirl. It has provisions for setting the center of balance. A threaded rod that allows you to adjust the mounting points relative to the center pivot.
My question is is there an easy way to determine which way you need to go initially to establish that center of balance? Any tips, tricks etc. for getting there or do I just have to slog through it and figure it out myself? The instructions have nothing on this. Everything is greased and ready to roll at the moment.
Thanks,
George
TripDeuces is offline
Old August 22nd, 2016, 04:06 PM
I haven't found anything better than trial and error with mine.
joe_padavano is online now
Old August 22nd, 2016, 04:49 PM
Use a helper is all I can tell you until you get it balanced.
Koda is offline
Old August 22nd, 2016, 08:32 PM
TripDeuces's Avatar
Thanks for the input Joe P. and Koda. Guess I have to call my best friend over.
Maybe my GF, she's buff
Old August 22nd, 2016, 09:19 PM
Funkwagon455's Avatar
The closer you get the adjustment to the center of balance, the easier it will be to roll the body over. Just like mounting and engine to a stand, the closer it is to being balanced, the easier it will be to rotate. I'd just adjust it to the easiest center of balance and call it good.
Funkwagon455 is offline
Old August 23rd, 2016, 04:24 PM
TripDeuces's Avatar
Success today. I set up the pivot points on level with each other and just instinctively realized that my center of balance should be closer to the floorboards because it's a convertible. It was low so I started cranking them up and every inch or so I tried the balance. It was bottom heavy and wouldn't hold position and kept wanting to flip back. After about six inches of rise it settled in and holds wherever you set it now. Very happy with this set up.
Thanks for all the advice it paid off. Was easier than I thought.
Old August 23rd, 2016, 08:00 PM
steverw's Avatar
Cool deal man, i love mine. looks great, have fun with it.
steverw is offline
Old September 11th, 2016, 11:33 PM
Bernhard's Avatar
Nice. What brand is it and are you happy with the quality?
A good friend is at the exact same stage he needs to mount his body to a rotisserie for media blasting.
Bernhard is offline
Old September 12th, 2016, 07:34 AM
TripDeuces's Avatar
Bernhard, this is the one I bought:
http://www.bestbuyautoequipment.com/...al-cr-3000.htm
The quality is decent. It's not top of the line but is rated at 3k for weight which it will never see in my garage
Old September 12th, 2016, 09:23 AM
Bernhard's Avatar
Thanks for the reply
It looks like a good unit with lots of options, the price is also very good.
Bernhard is offline
Old September 12th, 2016, 03:01 PM
Gary
Gary's 2 442-S's Avatar
Just like the one I have but from a different company.
Gary's 2 442-S is offline
Okie Rocket
August 15th, 2013 06:01 PM
outlawspeeder
April 23rd, 2013 03:34 PM
CLcutlass
November 2nd, 2011 07:55 PM
macrover
September 13th, 2011 11:41 AM
BigBertha442
February 24th, 2008 12:44 PM
Quick Reply: Rotisserie Help
