Wanting to do a semi restomod on my 64 Ninety-Eight
Old October 2nd, 2018, 06:26 PM
nspec's Avatar
Hey guys. So my original motor has a knock in it. Im planning on keeping the car for a while but wanting to swap in a newer fuel injected V8 with an auto along with some other upgrades.
I want to find a wrecked donor car, such as a 2009 Camaro V8 with an auto, or possibly a Gen 2 CTS-V (most likely not unless i find one super cheap)
Along with the swap, i want to upgrade all the brakes to disk brakes from the donor car as well.
What would be a good car to go with?
Any one swapped out motors with a late model V8? Wanting to do it within decent price range.
I'm not looking for high performance or show car quality stuff either, just something very reliable and get all the parts from a donor car.
I tried searching but had too much to go thru and I'm short on time for now.
Thanks in advance!
nspec is offline
Old October 3rd, 2018, 03:51 AM
That's quite a monumental task. If you're interested in a late model fuel injected v8 I would suggest checking out crate engines available at Summit or Jegs. You'll have to most likely replace the Slim Jim Rotohydramatic transmission which would mean major floor surgery. The TH400 and 700R4 are quite a bit wider than the Slim Jim (thus the name). You can probably find a kit for aftermarket disc brakes from Scarebird. Good luck, post some pics once you get a chance.
Olds64 is online now
Old October 3rd, 2018, 06:53 AM
Gearhead
Jon442's Avatar
An LS motor of some stripe would probably be the easiest, given the amount of aftermarket support, It still will require a good deal of fabrication. If you're skilled in that, no problem. But if not, prepare to spend some big bucks. Don't rule out eBay for parts acquisition. Five years ago I bought a 6.4 Hemi crate motor with all the accessories for $7500. Plan on floor surgery for the trans, no matter which one you go with.
Good luck with the project and keep us posted.
Jon442 is offline
Old October 3rd, 2018, 06:14 PM
Phantom Phixer
Charlie Jones's Avatar
Are you using premium (93 octane) gasoline ?
Charlie Jones is offline
70chevrolet
Non-Olds Engines
30
December 18th, 2018 08:25 PM
lsutigers93
Non-Olds Engines
May 1st, 2012 07:01 AM
64Super88
19
December 8th, 2009 12:58 PM
RatRod
Ninety-Eight
18
March 30th, 2007 07:35 AM
<c. larson>
Cars Wanted
September 23rd, 2006 05:57 PM
Quick Reply: Wanting to do a semi restomod on my 64 Ninety-Eight
