Twin J racing's '71 Cutlass Project Thread
This Is my 71 Cutlass drag car. It has a 461 Olds BB Th350 and 10bolt 8.5 rear end. I got It when I was still in High School it had been sitting for five years. A good friend got it and put it together and Raced it a few times. It ran 15.50 all day long all stock. I was looking for a 70-72 GTO or Lemans but he made me a hell of a deal on it. So I got it from him and started to play with it. frist off it got a 455 then a roll bar and many outher toys but no pic on the computer. I raced and played with till The fall of 2002. Then I was put up in 2003 since my trany was smoked and I finshed the 2002 season with a friends pontiac motor. That was also when my twins were born. Then went on back burner for years. So 2011 I finaly got the parts together and get it done.
So that Kind of brings us to 2011 where this will start.
Putting new motor together.
Botom End: It is a stock crank, stock rods, Sealed Power L2323F30, BHJ harmonic balancer. and a WJ the wheel all balanced up.
Heads: J heads ported up, EGR filled up, SS milodon valves, and milled and taped for 7/16 rocker studs
Valve Train:Lunati cam #51805 lift at valve .563 duration at .050 244 avertised duration 304 lobe separation 110. 1.6 comp alum. rocker arms, and a Edelbrock timing chain
Victor Intake, Demon 850 carb, Taylor Thunder volt 8.2, and a MSD distributor and HVC coil.
Got the car out to start working on Putting the motor and trans in it
My son Driving
Motor Going in
My son Driving
Motor Going in
Sitting In drive way
and Racing
Now that Brings us to 2012. last year the car didn"t run the numbers I want it to so back out it came. Changed timing chain to a Cloyes Hex-A-Just chain, a two peace timming cover, and checked and a few thing.
Poshed up Rims this year
Changed My MSD box from a 6al To a 6 PLUS
Did my front Brakes with new wheel Cylnders since they were leaking
Motor Ready for Dyno
Motor on dyno
Video of a dyno pull
450 HP 530 Torque
and Racing
Motor on dyno
450 HP 530 Torque
Put Motor Back in With New converter lower stall
Changed tach since the old one went out at the track last year and i put this one in to get buy but no shift light.
Still Need to finsh shifter some day
Update After a week end of racing 12.16 was the best 12.20 most of the time 108 MPH I"ve got a few video but they won"t up load so I will get them later
Gage wiring always fun
Now you see them
Now you don"t
New dip stick
Some thing missing here?? Took out for new gear
That"s beter
Now you see them
Now you don"t
New dip stick
That"s beter
Ready to go
One @ us 131
@ OC
The fan club after round win
I pulled the intake today changing it from a victor to a torker see if that helps any. Also had the pass side lugs losen up and hit the wheel cylnder and bend the backing plate so I guess it"s time for disk brakes.
Look at the wheel cylnder n the pic
Took my intake off new one is at machine shop to have milled so it will fit right.
My new intake and the old one
And on the car I"m going to try to work on tomorrow
Got the motor back together and running
One @ us 131
@ OC
And started to convert to disk brakes
And some new parts
Well after a few days of vaction Got to spend some time with the cutlass yesterday but I for got to take pic. Finshed the brake converson. Put one of these in Amazon.com: Allstar ALL48025 Brake Proportioning Valve: Automotive. And hung my exhaust system so I can play on the street. Went to change oil and the parts store gave me the wrong filter so I"ll get the right one to day.
well Sun went good and bad. It went a new best time of 12.03 but fried my MSD box. My track raind out so I had trailed to another one twice as far a way. to make one pass.
I remounted the MSD in the car after a got a new one :blackeye: . Went racing last sunday ran 11.90 all day redlighted second round :doh: :doh: . but a good day all and all.
Went to my OLDS Powere race tyhis week end ran best of 11.86 in the good night air. The only work I"ve done to the car is add a ford style starter solenoid since it wanted to not start off and on. Pic from the olds week end
And some new parts
Had the car out a few times still running 11.90"s all te time. I won the run for money at martin US 131. Well now its time to pull down for the winter.
Body
Fix all dents dings, and rust repaint. Lighten up door"s put new hood on.
Interior
Pull dash clean and dye black. Have all seat redone. New door panles and carpet. Maybe a head liner.
Pull out Change heads to my Edelbrock ones. Maybe go to 1.7 rockers. Dyno motor play with my different intakes and different headers I have.
May be more but that"s the plans now.
10-16
Put on new tunk
And started to pull motor
Got it ready for body shop.
Motor and trans out
Gutted and ready
The bumper fell off LOL
Even changed the tires
Motor back together and at dyno with new edelbrock heads
526 HP 602 LB to day on dyno
That's where I'm at now still waiting on body man.
Body
Interior
10-16
Put on new tunk
Motor and trans out
Gutted and ready
Dyno sheet From the outher day I hope it works and is read abale
Here's one I found of when I first Did the body work in High School in '97 Not a great Pic but some thing
I guess I thought the scoop would make it fast
Some pictures of it in verous stages of body work.
Got it painted last night
Lazy Dog
I know its a new thread on here but I painted the car 11-5-13 and this is the onthing I've done since then sad for me.
Any way I finally decided on front seats. And now that Norwalk weekends are over. And racing starting to wind down I'm going to get rolling in this I hope. But a quick picture of the seat
but I've got a long way to go. Baby steps I hope till it's done
Lazy Dog
