Rebuild on Stock 350 motor finally started
#44
Thanks - that's the way it was done from the factory for the Supreme in 1970 and I believe in 71 too. For 72 I'm pretty sure it goes all the way to the front and bottom on the sides.
#45
video of motor:
More pics of car with new paint and vinyl top - car is extremely dirty and motor is out so front is sitting WAY up:
#47
Thanks! Really happy with how the car is turning out. Paint ended up even better than I had hoped. The pics don't do it justice and it's still really dirty. The video of the motor doesn't capture how crisp and responsive it runs. Since I asked Frank to use a cam I already had for the build I was nervous how it would turn out and Frank was too. We were both a worried it might be a little too big but it seems to be a great fit with the 374 and the Rhodes lifters. Can just barely hear the ticking. Really excited to feel how it drives with this motor and the upgraded 2004R trans and converter.
#49
The vacuum gauge showed 16" of vacuum during that video but the the tachometer was NOT hooked up. It sounded to me like it was idling at a higher RPM - like around 1,100 -1,200 or so. I bet if the idle was dropped to around 850 - 900 it would be in the 13" - 14" range and the idle would have had more of a lope. Also since the Rhodes lifters usually add about 3" of vacuum at idle it probably would be around 10 or 11 w/o them at a lower RPM.
#50
2004R is out of the car and on it's way to Lonnie at Extreme Automatics to be upgraded from a Stage 1 to a Stage 2, a deeper Hughes pan, and a new 3000 converter that will be better suited to the upgraded motor.
#52
-Joe
#53
I found the 4L60E filter fit better than the 700R4 filter with Hughes pan. Made it easier for me when I still had the Olds powered 4x4. It only leaks a small amount, down to seepage. I wish there was a pan gasket like factory 42RE, rigid carrier with rubber sealing lines throughout. I have used this pan on 3 different 2004R's, so it isn't the trans case. It leaks a small enough amount that I can run it down the track, shoot it down with brake clean when I get there and rarely have to add trans fluid. If you are not racing with slicks, it will be fine. I am glad he adds the billet forward shaft in his Stage 2 trans, I will be buying the whole billet foward shaft/drum assembly when my stroker is done, stock can't live over the Olds torque past 400 ft/lbs.
#54
So I had a long talk with Lonnie about the 2 pans. He said the Sheet Metal one looks really cool and works very well but it just will NOT seal 100% correctly and he said he would not guarantee it against leaking. So I'm sticking with the Hughes which he said he would give his personal guarantee it would never leak. Very strange. Sounds like the opposite of what you said. I am obviously going with what Lonnie suggests especially when he tells me he will cover it if there's an issue.
#55
Trans is all done and on it's way back to the car. Here are the final specs:
Extreme Automatics Stage 2 build w/Hughes deep pan setup for 6,000 - 6,200 RPM WOT shifts, R&R 9.5" 3000-3200 non-lockup converter
#56
That sounds awesome. Interesting on the pan, Dr Dan Mascal swears by those sheet metal pans. I love how my 2004R behaves stock under light throttle, firm when you stomp on it.
#57
Yes but your question was only meant to inflame someone else, don't deny it, you only wanted to "hear yourself say something" and pretend to be right all the time.
#58
Here's a full summary of the car I put together. Items in red still need to be done:
1970 Cutlass Supreme
Azure Blue paint (paint code 20) with white hood stripes, white vinyl top & blue interior
2004R Trans Extreme Automatics Stage#2 w/deep Hughes pan governor set for 6,000 RPM WOT shifts, R&R 9.5” 3000-3200 no-lockup converter
Brian Trick 3.90 posi rear, Jegster adj upper & lower control arms, Hotchkis trailing arm braces, Hotchkis 1” rear sway bar, W-27 cover, Hotchkis rear spings
Tubular upper and lower front control arms, Hotchkis front springs, hallow sway bar
[COLOR="yellow"]Stock Manual front disks and drums rear
374ci Build w/#s matching 350 Olds block:
Bore 4.125 SRP pistons (.068 over) 21 cc dish
Stroke 3.5 (330 steel w/2” journals)
Rods 6.125 Dyers H-Beam
Holly Street Dominator
Edelbrock 1411 750 cfm 4-Barrel carb with electric choke and bowtie’s adj TV cable for the 2004R
UD 292/300, 235/244, 522/536 (1.6 HS rockers), 112 – slow ramps – w/ Rhoads lifters
9.57:1 measured CR {zero deck .041 gasket, 1.425 comp ht, 9.3 deck ht} /175-180 cranking compression (Rhodes Lifters increase by about 10 -20 at idle)
#6 heads – 59.5 ccs, 2.07/1.68 valves, crossovers filled, fully ported
7 QT Oil pan
American Racing 1 3/4" stainless headers, 2.5" exhaust (Xpipe, mufflers, tailpipes, & Olds trumpets)
Summit 380457 3 core alum radiator with trans cooler – stock fan & shroud
180* thermostat – Mr Gasket #4364
#8529 MSD Pro Billet Dist w/Vacuum Adv
#8207 MSD Blaster SS coil
MSD 6AL box w/6500 plug
MSD #31363 8.5 mm spark plug wires
Drive shaft loop
Stock rubber 350 motor mounts with tie down rod to frame (via alternator bracket) on drivers side
Factory AC with upgraded compressor (Pro6ten high performance 21 lbs lighter than stock (15lbs vs 36)), & parallel flow 6mm condenser w/6 rectangular tubes {part # 11-803P Classic Auto air} - with R134 conversion - blows ice cold even at idle and/or low RPM.
15x7 front/15x8 rear all chrome SSIs
245/60/15 front - 275/60/15 BFG RWL tires
About 3900 lbs with driver
7 QT Oil pan
Drive shaft loop
#59
Inflame who?To the op car looks great. Did you have trouble with the fit of your headers?
#61
Sorry for the long delay on this. As a reminder this was a graduation present for my son. He graduated in May from VMI and is now a 2nd LT in the Army. Trouble is he had to go to Fort Knox first, then Fort Leonard Wood, MO (where he is now) and will end up in Fort Campbell, KY in 2017.....so he can't take the car for a while. Because of that the push to get it done for graduation was gone. The car will actually go to my Dad's house in Northern VA and he said he would be glad to keep it garaged, drive it, pamper it, and take care of it until my son is settled and can take it as his own.....so the work has finally started back on the car. Engine compartment is being detailed this week. Upper and lower control arms and brakes are going in. The motor and trans should be back in the car by next week. Will be adding pics as I get them over the next few weeks.
#62
Before pics on the engine compartment:
POR 15/primer:
New upper and lower control arms:
Painted fender wells:
painted compartment:
POR 15/primer:
#64
For the engine compartment they have a several step process that starts with disassembly, then cleaning, wire wheeling, & power washing. Followed by POR 15 treatment for any areas that need it, then primer, then they cover everything with Chassis black. The transformation from start to finish is impressive.
Here's the final product on my 442 but the pictures just don't do it any justice.
#67
Haha - thanks guys. Can't wait to see the finished product except with the gold instead of the blue!! ...and then of course see how the new motor and trans are on the road. I will have to make the 4 hour trip up north to test drive it and check it out when it's done. Will drive my 442 up when I do so Frank and his brother can do a few small "add-on" projects for me (oil cooler and a fix for vapor lock I've been having).
#68
Motor and trans are back in:
lower control arms are installed:
#71
Thanks - really happy with how it came out.
#73
#74
#75
Well no test drive today but manual front disks are on, tach is finally working. Got a few more things done. Here's a few more pics:
#76
Finally got the car to a stopping point. Still a few small items to be finished up on later but surprised my Dad with the car on his Bday on Saturday. As a reminder from an earlier post he will keeping the car as his own for several years until my son has a garage to keep it safe. It looked like it might be done in time so I drove 4 hours up to Frank's, picked up the car and surprised my Dad with it - he said it was the best Bday he ever had:
He and I went on several long drives over the weekend. My 79 year old Dad was like a kid again doing big nasty burnouts and chirping the tires on the 1-2 shift. You couldn't wipe the smile off his face. Really happy w/how the car came out and it's a blast to drive w/the 3.90 gears 2004R trans w/OD for the hwy and the built up 374 stroker SBO. Guessing power to be around 420/420. The stage 2 trans drives really mild when you granny drive it but comes alive at WOT!!
Here are some more pics:
Final details on car:
2004R Trans Extreme Automatics Stage#2 w/deep Hughes pan governor set for 6,000 RPM WOT shifts, R&R 9.5” 3000-3200 non-lockup converter
Tubular upper and lower front control arms, Hotchkis front springs, hallow sway bar, QA1 single adjustable front shocks
Airtex 40736 70 Toronado manual fuel pump
7 QT Oil pan
Drive shaft loop
7 QT Oil pan
Drive shaft loop
#79
Thanks!
Thanks - not sure where I wrote it's at 1900 RPM at 60 but I think it closer to 2200 or so at 60. I was just checking the RPM ranges when my Dad and I were cruising this weekend. I'm happy with where it is. Hwy cruising is really nice at any speed.
In my opinion the 3.90 gear, 28" tire, and the 2004R is the perfect combo for both off the line and hwy cruising. Cruising at about 70 mph in OD/4th and putting the pedal on the floor and feeling the trans downshift to 3rd and and the governor holding it in 3rd until 6000 RPM is awesome. This SBO likes RPM. The governor is tough to get dialed in but Lonnie at Extreme automatics nailed this one. It shifts almost exactly at 6000 RPM at WOT in all gears which is exactly what I asked him for. Really fun car to drive and drive hard.
