Convertible top frame
Next on the to-do list for my 68 442 will be stripping off the old canvas and establishing what needs to be repaired or replaced as far as the top frame goes.
This will be entirely a new project I haven't tried before. Any hints ahead of time would be greatly appreciated.
The top motor does function properly but the top does not fully reach the windshield header. Falls short. The canvas is history, lots of rips etc, so I don't need to be carefull about taking it off whole. I do know that there are a few pivot point in the frame where the correct bushings are missing and will need to be replace. Sources?
Also I do expect to refinish the frame itself. as seen in the photos, turned out dark, the frame appears to be gold. Factory color? I just thought they were all black, but I like the gold.
Also I won't be tackling the replacement top install. I'm located in Toronto, Ontario, so any leads for installers would help too.
The rear trim stick should be marked where the top is stapled in regards to the rear curtain. Or leave the top and rear curtain stapled to the stick and give it all to the shop doing the top.
This is JMHO, but after doing mine without a old top, I would think even a professional shop would prefer having a old top to go by.
You should be able to get a kit with all bolts and bushings for your app.
I completely disassembled the frame on my '68 Skylark convertible. restored the frame and re plated ALL the hardware. I suggest a diagram in addition to photo's if you disassemble to this level to make re assembly easier.
Hydro- E-lectric in Florida has many of the hardware and bushing I believe. Mine were all in good condition save for 1 replacement hardware bolt.
Never seen color coated frames before ? just black.
'68 green interior cars, had green top frames for converts. Ed Mann in Caledon does good work. Not cheap though. 905 880 1366. He did the top on '62starfire63'. Looks great. Check pics on his posts.
My 69 442 top frame was blue, and the top was also....doing another 69 now, and it also had a blue top / blue frame...
I would guess that your willow gold frame had a gold top on it...
Good luck on your adventure...
tim
i have pics of the original blue frame somewhere, if I can find them, I will post them...
tim
tim
tim
oldspackrat
December 21st, 2012 08:27 PM
oldsmobilty
September 27th, 2012 04:26 PM
Olds luvr
December 2nd, 2010 08:26 AM
