1964 Olds Dynamic 88 resto
Old January 9th, 2013, 10:26 AM
Kid64's Avatar
Figured id post a progress thread
Kid64 is offline
Old January 9th, 2013, 02:36 PM
rktolds's Avatar
Nice ride. What are the plans? I have a 66 Dynamic that I will start working on this Spring. Gonna be a cruiser. I will start a build thread when I get it to the house. Good luck with your project.
rktolds is offline
Old January 9th, 2013, 02:43 PM
Kid64's Avatar
Thanks! Right now im going to restore it as much as I can. Needs a radiator which im waiting on now. I'd like to make it into a daily driver. I'd also like to put some airbags on it and drop it low with some white wall tires. Itll also be a cruiser. Would like to see your thread when its srarted.
Kid64 is offline
Old January 10th, 2013, 05:21 AM
Kid64's Avatar
Before
After
Found this under the mat in the trunk
Kid64 is offline
Old January 11th, 2013, 10:13 AM
Canuck 88
Greg N's Avatar
Hey Kid,I like what you've done with the trunk.How did you get that original look coating?My 62' could use the same treatment.
Cheers
Greg
Greg N is offline
Old January 11th, 2013, 10:21 AM
Kid64's Avatar
Hey Greg N,
Well i did the usual cleaning and sanding of the surface rust then i treated it with ospho to kill the rust and prep for paint. The paint i used is from any auto parts store. It's a "spatter" paint that comes in black and white and the grey and white that i used. It's got more texture than original but it looks close enough to the color to blend in well. Like an idiot i used Primer that i had laying around (black) and it took me 4 cans to cover it up. I don't think it needs primer but i did it anyway. So anyways Spatter paint from advance auto parts in grey and white
Kid64 is offline
Old January 11th, 2013, 10:34 AM
Canuck 88
Greg N's Avatar
trunk paint
Right on.Thanks for that.That sounds like a fairly simple solution and it looks really close to original in the pics.At some point water got into the side wells and some rust formed and peeled the original coating.The rest is pretty good so I will be trying to blend it a bit.I haven't peeled the mat back yet,but now that I see what you found underneath I'll be right on it!
Thanks again
Greg
Greg N is offline
Old January 11th, 2013, 10:37 AM
Kid64's Avatar
No prob Greg have fun!
Kid64 is offline
Old February 10th, 2013, 08:19 PM
Phantom Phixer
Charlie Jones's Avatar
What you found was a build sheet. This sheet came down the assembly line with the car and told the workers what options, colors, or upholstery that particular car was supposed to have.
Charlie Jones is offline
Old February 11th, 2013, 07:57 AM
Canuck 88
Greg N's Avatar
Right on Charlie,I kinda figured that was a build sheet.No luck on my car though.Nothing under my trunk mat but a tarry mess!
Cheers
Greg
Greg N is offline
Old February 11th, 2013, 08:44 PM
Phantom Phixer
My 63 didn't even have a trunk mat. What it also didn't have much of was rust. Only a light coat of surface rust on one side.
BTW does anybody know where I can get tan colored spatter paint?
Old February 21st, 2013, 09:41 PM
64Custom's Avatar
I like your build, I'm presently redoing a 64 Olds 98 Custom Sport. I did some extensive body mods and have installed a 454 in it. I had Dakota Digital make me a dash panel and I've installed a Flaming River tilt column and wheel. I also had front disc brakes made up for it, and will put it on 18" wheels.
64Custom is offline
Old February 24th, 2013, 05:57 PM
Kid64's Avatar
Nice! Sounds like a lot of good work
Kid64 is offline
Old February 24th, 2013, 07:40 PM
Registered Luser
ent72olds's Avatar
Kid, trunk came out very sweet!
ent72olds is offline
Old July 11th, 2016, 11:18 AM
BillJack's Avatar
'64 Custom Sport Coupe
I also have a '64 CSC. I'm thinking about putting a 455 into a '64 Dynamic 88. What did you have to do to fit that engine in your car? What transmission did you use?
I want to put in an Olds 455 with a five speed manual transmission, at least that's my plan.
BillJack is offline
Old July 11th, 2016, 02:48 PM
64Custom's Avatar
I made up a pair of motor mounts, and custom fit them to the frame, and I installed a 4L60E tranny with a TCI programmable controller. The 454 is actually 5" shorter and narrower than the 394. It is also 30lbs lighter.
64Custom is offline
Old July 12th, 2016, 11:36 AM
Don R.'s Avatar
Kid64, I hadn't seen your thread before. Have you made more progress since 2013?
Don R. is offline
Old July 12th, 2016, 02:41 PM
StarGeneral's Avatar
Hey man! Looks real good so far. You did some awesome work on that trunk looks great! Hope to see more progress as you go along - best of luck
StarGeneral is offline
Old July 13th, 2016, 03:26 AM
BillJack's Avatar
Awesome. Thanks for the info.
BillJack is offline
K-Dog
April 11th, 2015 07:09 AM
1964F85
March 3rd, 2015 12:59 PM
rbanks40
Cars Wanted
June 9th, 2011 02:27 PM
fastvan67
April 19th, 2007 05:14 PM
MWS88Dynamic
January 16th, 2007 12:40 PM
Quick Reply: 1964 Olds Dynamic 88 resto
