1963 Dynamic 88 2dr hdtp. restoration
#41
Hurst mounts !! Grrrr
My car came to me minus it's engine and trans. Unfortunately, some idiot had tried to install a small block Ch@*y in it.
They had cut holes in the frame crossmember and then welded on a set of Hurst mounts. Somewhere along in the project it was abandoned.
It wasnt bad enough that they welded the mounts to the frame crossmember . But they also cut big holes in the crossmember !
This was probably to better access the lower mount bolts???
I'm in the process of removing them. Assisted by a grinder, a hacksaw and a sawzall I have cut one free and now I'm grinding all the welds off.
Is there anyone out there that has a rusted or otherwise junk frame, that would be willing to cut pieces out of it. So I can patch this one? I would be willing to pay them for their time and effort. As well as pay for shipping.
Please P.M. me.
Please P.M. me.
#42
No expert here, but how about finding out what kind of metal the frames are made of and then picking some up at a local metal supply outlet? Just recently I even heard of this company that will come to your garage and fab up and weld patch panels for you. Or you can make patch panels yourself. It would be easier than finding someone with an abandoned frame that's willing to do all that work.
#43
Back to the old "grind" again today (literally).
Time was spent between grinding welds off right mount and hacksawing left when my small "el cheapo" grinder got too hot.
#44
Still chiseling away at the Hurst mounts. I got the right. side all cleaned up and ready to be patched. Got the left mount off and now I'm grinding the welds off.
Right side is easy to make a patch for. The left side, however, is a lot trickier. That's why I entertained the idea of useing patches cut from a junk frame.
Anybody want these d@#n things? Please PM me.
#46
Advice needed- Painting the grille
I took the grille apart and cleaned it up today. The chrome cleaned up nicely. ( I love New Mexico Cars!)
However, much of the grille is painted a silver color. The silver painted part had way too much "patina" to suit me. In some places it was worn through to the metal.
I felt that I HAD to try to re-paint it. I went to Ace Hardware around the corner and took 1/2 of the grille. I found some silver paint that looked like it MIGHT match. ( At least it pretty much matched the cap.)
I took it home and shot the grille with it. I'm not very happy with it.
A couple of photos below show the difference. The grille I re-painted is shown in the foreground, and the unpainted original section is behind it.
My question is,; What kind, type, or color was the original paint? Paint formula numbers etc. would be very helpful.
#47
New (to Me) sewing machine
As I had mentioned in post #20 I had been looking for an industrial sewing machine. Well, I got lucky and found one.
It's an older Consew but it runs, well, like a sewing machine!
I got it off E-bay and the machine was near Atlanta, GA. I paid $400.
The seller would not ship. So I took the back seat out of my Dodge Aries and drove up to Atlanta. (500 mi) I broke the machine down and loaded it in the car. The next day I drove back to Orlando.
This was a win-win for me and the wife. I get a machine to do my interior for my car, ( and probably others after this) But, she gets a machine so she can set up a small business doing headliners and seat covers.
The nice roller work tables in the last pic were included in the deal. But I left them there, because they would be more expensive to ship than to build new in Orlando. The trip up there to get the machine cost $238.
#49
About 20 years ago, my wife and I both took auto upholstery night classes at a local tech school. I was restoring a 57 Olds at the time. I did that interior. Plus a couple others for friends. We also did a lot of glue- in headliners. It was an open ended course and we just kept taking it over and over.
Unfortunately, they don't offer auto upholstery any more.
We have both been practicing with scrap materials. And will make several practice seat covers before making them out of $89 a yard material.
Boy! I thought I got a bargain on my machine . You really did!
On the flipside, not everybody wants one of these beasts. And transporting them is no piece of cake either.
#50
front seat teardown
I started to work on the front seat. I will put new seat foam on it and then make a practice cover out of some material that I got for free.
Fifty years in the desert sun didn't do this upholstery any favors!
The seat backs were removed first. After the protective cover is removed from the outer seat hinge, the clip on the outer hinge can be pried off.
Pulling outward on the hinge will dis-engage it from the pin. Then the seat back is moved forward and lifted by the outer edge up and out.
The pics will explain better.
#51
Front seat teardown
The upholstery and padding of the seat is held to the metal frame by "Hog rings" (so named because farmers put them in the snouts of hogs to keep them from "rooting" or digging with their noses).
The easiest way to remove them is to cut or break them with a pair of dykes.
Grasp the ring with the tip of the pliers and squeeze HARD. then twist the pliers a quarter to a half turn. The hog ring will usually break. If not, repeat.
The outer seat cover will be removed first. Take plenty of pics or make notes as to the location of all those hog rings, so that they may all be properly reinstalled when you assemble the job.
#52
front seat teardown
The next step is to remove the padding if necessary. If the seat came from a northern, garaged enviornment the padding might be ok, Mine came from the southwest so it was like Texas toast, really!
I'm hoping that the seat foam for a 63 Impala will fit. They are available from several Chevy suppliers.
Does anyone have a Hollander book and can tell me If 63 Dynamic 88 and 63 Impala front bench seats are the same? Thanks
#54
Loving this thread, Keeping it original while choosing your own color combo, just like you would have in 1963 at the dealers desk. I too have the 63 Dealer book. Are you going with Regal Mist or Holiday Red for the paint?
#55
I'm going with the 62 Olds garnet mist, just because I like the color better.
Besides, it was a 63 interior color.
This car will be equipped with a 4 speed stick. They weren't officially available from Olds (although they built a few for test purposes).
I definitely DON'T want another slim-Jim!
The car was originally a C60 (Air conditioning) car.
I will also be installing an original AM/FM radio in place of the AM only radio.
It will have a Starfire 345 HP engine.
And finally, dog dish hubcaps with large blackwall tires. For a "factory hot rod" look.
#56
my uncle had one of these in the early 80s daily driver. beige with a beige interior. super clean in and out with a rotted rear bumper {that never made sense to me} i think the motor took a dump and off it went to the junkyard. i always thought they had great lines to them and would love to find a nice solid stock one to have. yours will be really cool with a 4 spd. great work keep it up!!!!
Charlie,,,
Charlie,,,
#57
I'm prejudiced of course, but I think the 63 Olds 88's had the cleanest styling of any of the 61 to 64 GM cars.
The 63 -64 cars had a "boltless" bumper that had the bracket welded to the backside of the bumper. Unfortunetly it formed a "pocket" where dirt, debris, and moisture would collect and rust the bumper out from the inside.
#58
Judy's Auto Upholstery
I'm sorry I haven't posted for a month.
I've been busy getting our upholstery shop together. I've got almost all the permits etc. and we will start advertising next week.
We plan to do antique, street rod, and custom work as well as "production " work.
If any of you need upholstery please give me a call at 407-358-9855 or 407-968-0835 or E-mail cjones1350@cfl.rr.com
For those of you that are out of the central Florida area I may do seats and door panels on a "ship and return" basis.
#60
I would like to second the notion that the '63 had the cleanest lines of the 60's era Olds.
At one time or another I had a 60, 61, 62 and 63. My '63 Dynamic 88 convertible had the smoothest, simplest, cleanest lines of any of those years.
#61
Finally got my @ss in gear!
After not doing too much the last several months I purchased a small sandblasting cabinet at a pawnshop for $50.
I started sandblasting and painting small parts such as door hinges and front end parts.
#63
Door hinges
I got hinge rebuild kits from Obsolete Chevrolet in Nashville, GA
Being a Fisher Body part the hinges are the same as Olds.
The kit contains all rollers, bushings, pins, and springs to rebuild the hinges.
#65
Pontiac pedals
I finally got the right pieces and mocked it up today.
The clutch and brake pedals and hanger bracket were from a 64 Pontiac with power brakes. (A 63 unit is also the same)
It bolted right up to the stock Olds power brake unit .
Now, all I gotta do is fabricate linkage and a "Z" bar.
#66
Charlie....do you like New Mexico cars? Lol! I love the car and the price you paid! Nice to see one of these old girls get some love! Super clean car. One of my favorite cars I ever had the pleasure to own, was a '63 Dynamic 88 Fiesta Wagon. I still have some spare parts lying around from it.....
#67
wiper motor
I haven't posted in a while , but I'm still chipping away on this project.
I just finished the wiper motor. I disassembled it and cleaned everything .
Brushes looked good ( New Mexico car , so I guess the wipers didn't get used much). Re-lubed and assembled. I polished it with fine steel wool and it looks like new. I put a re-build kit in the washer assembly, which consisted of a diaphragm and new valves.
#70
I still have all the wiggly bits to do once I get the major stuff out of the way, these threads give me the courage to tackle stuff that previously I might have just thrown some cash at ,
Thanks for sharing
#71
The body is off
After a long slack period I'm finally back at it again.
I finally pulled the body off the frame today and mounted it on my "Hillbilly Rotissarie".
Next project is to strip all the suspension off and get the frame powdercoated.
Then... I can get started putting it back together!
#72
Soo good to see a 63 getting the love it deserves. Keep punchin. I drove my Starfire daily up till last week when the roads got salt om em. Best car ever. If you want to drive it much I'd recommend a better tranny and a rear sway bar. Then it's just a perfect driving automobile.
#75
stripping the frame
I got everything off the front of the frame. Next comes the rear end, then it's off to the powdercoater's.
I'm spending Cutlass/442 money and attention to detail on a Dynamic 88.
ABSOLUTELY CRAZY, HUH?
#78
Got an engine now.
The deal on the engine in post #7 fell through. But.
Thanks to "Lansing" (Ralph Young) I finally have a rebuildable engine.
Came to me from Missouri today via Fastenal shipping.
Donor was a 63 Starfire with a badly rusted frame.
#79
Nice engine for your project. The dual exhaust manifold is worth a small fortune. Good to see that it wasn't damaged during shipping. What extras are you planning for the engine rebuild?
Steve
Steve
#80
A lot of people are ASKING big money for dual exhaust manifolds. But who's paying it ?
I paid about as much for the whole engine as some people are asking for a pair of dual exhaust manifolds.
Us "darksiders" are cheap S.O.B.'s. Even the Starfire guys.
I was lucky that there was no shipping damage as the engine did tip halfway over during shipping due to a collapsed support.
I'm doing just a stock rebuild for now , although I may go to a little more radical cam.
Someday, when I get more money than I know what to do with, I may just slap a "Tri-Power" system on the top.
