trunk tension rod help
Old December 19th, 2011, 04:33 PM
kansasculass's Avatar
I have a 1967 cutlass. Can anyone give me advise on installing a tension rod? I know its a stressful job and its not easy. But should the trunk be closed when installing? Im thinking it should so there is no tension. I dont know I could be wrong. And could someone please post a couple pictures of their trunk rods, One of each side. Thank you, merry christmas
kansasculass is offline
Old December 19th, 2011, 04:41 PM
Run to Rund's Avatar
You can make a tool to install them easily out of a piece of pipe with a notch on the end, and a carriage bolt through it cross-wise a couple inches down from the notched end. It will essentially duplicate the factory tool.
Run to Rund is offline
Old January 26th, 2012, 12:06 PM
tension rod install
oh I didnt know there was a tool for this. Do you know where I can find a picture Of this tool? Or can you post a rough picture of one so I can get an idea of what I need to make?
pizzyp
November 17th, 2014 01:39 PM
72cutlassolds
February 12th, 2012 11:49 PM
44blue
October 6th, 2011 10:05 AM
AZ455
August 30th, 2011 03:09 PM
bulldog
August 17th, 2011 08:25 AM
Quick Reply: trunk tension rod help
