Legendary Auto Interiors = Quality
#41
That spray stuff is a very thin layer. The factory jute was almost 1" thick, so you will probably need another layer. However, do a dry fit in your car to see what it is like. If it does not seem to rest int he floorpans, or there is space on the sides, then you will need extra jute.
I did not use any glue on mine, since it stays down well when everything is assembled. If you have glue, it could not hurt. I thought of it as too much of a mess-maker...
#42
Personally, I'd definitely put some OEM jute down or some of the aftermarket padding like Dynomat or the like. It'll cut down on heat transfer up through the floor.
I used as little glue as possible, because if I ever needed to get at my wiring, I don't want to have to destroy my Dynomat and carpet when I pull it up. However, because the carpets for the '68s fit so poorly, I had to use it in a few spots.
I'm sure Rob will chime in with his experience in his 72.
#43
The carpet will have the factory style jute glued to the back of it- so unless you want to use extra, there is really no need.
If it were me, i'd dynomat it, then just lay the carpet set over that.
I have the trim parts carpet in my 66 and i like it. I have heard many complaints (and experienced some) of the fit problems of the ACC carpets going over the transmission hump, and i was really happy with how the TrimParts carpet fit in my car. Hard to say for a 68+ carpet though as the floors are different from the 66.
The factory did not glue down the carpets and there is really no need- as the kick panels, firewall pad, seats & sill plates all act to keep it down and keep it from moving.
I would advise you to get the carpet out of the box, put it in a small room with a little space heater to warm it up really well for a few hours before you start putting it in the car.
When you put it in the car, try and keep the temp up inside the garage or in the car (i acutally put a space heater where my back seat goes and get it up around 75 degrees in the car)
This will help the carpet to lay flat and follow the contours of the floor. Even though they are preformed to fit the floor pan, the heat definitely helps.
When i did mine, as soon as i got the front peice trimmed and pretty much in place, I took a heat gun (hair dryer might work as well) really roasted the valleys next to the tranny hump up at the front, then put a sandbag in each valley to pull it tight- Not sure how much this actually helped me to prevent the puffy over the tunnel problem- but it was suggested to me, and i don't have that problem, so i guess it worked.
anyway, with the sandbags holding the carpet tight against the tunnel, i finished trimming the sides, re-installed the kick panels- and worked my way to the back.
A soldering gun makes a nice clean burn through when you need to locate your seatbelt holes, and the dimmer switch.
Also... if you would like to cut your carpet properly for your seats (both buckets, and bench seats) here is a little diagram i made up of how the factory cuts were. This made it so the carpet hides the seat frame feet. Can't even say how many times i've been at a show looking at cars, and see the seats just bolted over the top of the carpet.
Green dots show where the bolt/studs actually are
The results after you have installed the seats- No more ugly seat Feet!!
anyway, hope this helps.
#44
#45
What color for. Acc is this carpet?
Actually, it is not that much, given the beauty, originality, and value they will add to your car. 200 is what, three cable tv bills??
I am still , even a year afterward.
Can't complain with this...
Seat covers, door panels, & quarter panels all came from Legendary.
Carpet was ordered through them, but came from ACC.
Check out my interior thread for hints, tips, tricks, things to avoid, and to get the excitement building.
Post a thread on your progress, too!
#47
My door panels were pretty good - the only fit related issue is the that the windlace strip end was folded over which created a bulge that contacted the kick panels when closing the doors. It was not made like the originals. Not a big deal but they could improve that.
Also the perforations for the door lock switches were way off (I did not use them).
#49
Legendary Rallye Seats - Awesome in my book!!
I redid my seats last year. After some serious contemplation, I ordered the Rallye Seat Kit for my car. I also bought all new plastic trim pieces too. I removed all of the carpet and installed some Dynamat Extreme on the floors. My original carpet was in mint condition, so it was cleaned and reinstalled. The seats are super comfortable and very supportive. The quality of the kit was great!! I posted a few pictures for reference.
Thanks,
Rick
Thanks,
Rick
Charlie Jones
September 17th, 2013 01:00 PM
