HVAC control mounting repair
Two questions:
1. The plastic posts that the HVAC controller attaches two are all three broken. I have at least two (and a half) of the three posts - one split down the middle and I"m not sure I have both pieces. Anyway, I'm after suggestions on what to use to repair this so my HVAC controller will hold when mounted. I did a bit of searching in the forum and Q-Bond sounds like a potential fix. Is that the way to go. Anything else to do instead of that, or after using it?
2 How do I remove the wire/connection in the middle of the HVAC controller (arrow points to it)? I think it might be the backlight? It's the gray wire in the middle towards the right. does it just pull straight out the back?
HVAC Control, back
HVAC Control, back
My suggestion would be to epoxy small screws with their heads removed in the stands then use nuts to attach the control panel to the dash. Since the plastic is brittle if you build the up the stand using epoxy or other filler material then screw a self tapping screw into it it's likely the plastic will break/split again.
Thanks! Now that I think about it, it looks similar to the one on the top of the radio. I'm still getting used to this era of vehicle wiring.
