68/69 console
Old January 14th, 2019, 07:41 PM
servexcell's Avatar
68/69 console
Is there any modification to do to the shifter console when replacing 2 speed jetaway to Turbo 400 transmission?
I have a new kit with new lens and cable. Does the chrome plate hjave to be modified?
Bruce
servexcell is offline
Old January 15th, 2019, 06:37 AM
Bruce
The only changes are the curved gate in the shifter (so you have detents for all three forward gears), the gear indicator lens, the cable, and the bracket on the trans pan that holds the lower end of the cable. Everything else is the same.
joe_padavano is offline
Old January 15th, 2019, 08:00 AM
servexcell's Avatar
Hi Joe
does the chrome base that fits over the shifter have to be modified.
thanks
Old January 15th, 2019, 08:06 AM
Hi Joe
thanks
From above:
Old January 15th, 2019, 01:23 PM
69455's Avatar
I had to modify the top chrome plate as well as the curved metal gate to allow for extra travel on mine.
69455 is online now
Old January 15th, 2019, 01:33 PM
Then you did something wrong.
There is only one P/N for that panel on the 67-69 AT consoles - 396000 (without the applique). This is for both two speed and three speed applications. I'm guessing that your mods to the curved gate were not the same as OEM, thus the problem with excessive travel.
Chuxter
June 2nd, 2016 01:12 PM
4speed455
November 17th, 2015 02:55 PM
68442
December 31st, 2014 05:48 PM
Oldsguyhill
March 20th, 2014 08:30 PM
raider973
April 14th, 2013 02:59 PM
Quick Reply: 68/69 console
