Info needed for found Olds logo?
Point taken on the post. BUT, if you compare apples to apples the emblem is exactly the same. Yours is simply from the back side (as you know these emblems can twist around easily without damaging them); check the upper casting and you'll see what I mean. Those red inlays were notorious for coming off leaving simply a pot metal surface.
coldwar
November 13th, 2010 04:23 AM
