Quick 30 min Sunday afternoon project...
Old August 19th, 2018, 01:50 PM
72455's Avatar
So a couple weeks ago when I was on the hunt for my build sheet (still looking, btw) I pulled the back seat cushion to see if it was there, and I noticed some rust buildup on the driver side seat springs, so I added it to my "to do" list.
Today I got the chance to address the issue. I used a wire brush to knock off the heavy scale, then used.a rotary wire brush in my drill...cleaned up pretty good in my opinion. I was going to prime and paint the entire spring set, but I think I'll leave it as is. Do you all think I'll be ok?
Heres a couple pics...
72455 is offline
Old August 19th, 2018, 03:08 PM
72 Olds CS
RetroRanger's Avatar
Meh well it's out I would squirt it, but don't feel bad if you don't no one will see it anyways...now you know the MAWs....they creep into every aspect of owning these cars, making even the smallest projects twice as long or expensive. MAWs = might as well
RetroRanger is offline
Old August 19th, 2018, 03:16 PM
72455's Avatar
Lol...speaking of MAWs, figured since the back seat was out, may as well do some housekeeping .
72455 is offline
Old August 19th, 2018, 05:32 PM
Of course, the real question is, where is that water coming from? Side window weatherstrip? Pinchweld rust?
joe_padavano is offline
Old August 19th, 2018, 05:46 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I can see this turning into a frame off restoration. Get ready.
redoldsman is offline
Old October 1st, 2018, 11:21 AM
oletrux's Avatar
After the source (if any) is identified and fixed, POR-15 or Eastwood Rust Encapsulator is your friend...........at least in my world.......
oletrux is offline
Old October 1st, 2018, 11:45 AM
jaunty75's Avatar
Yes. Those springs and such lasted 46 years, and I'm sure they'll last another 46. They would have even if you hadn't cleaned them off, but now you've lost the patina!
jaunty75 is offline
troyd
September 15th, 2019 07:40 AM
70-442-W30
March 5th, 2016 01:10 PM
oldsguybry
November 5th, 2013 10:10 PM
richeyb
July 10th, 2010 04:53 PM
Cecil Anderson
Care and Appearance
January 4th, 2010 04:17 AM
Quick Reply: Quick 30 min Sunday afternoon project...
