Door backing plates - 72 CS
Old July 2nd, 2018, 04:35 AM
Apollo's Avatar
Hello,
Do I have to remove the inside door open/release handle in order to replace the door arm rest chrome backing plates ?
Apollo is offline
Old July 2nd, 2018, 06:32 AM
Originally Posted by Apollo
Hello,
Yes. Once you remove the outer arm rest, you will see the "C" clip that holds them in place. Simply remove the clip and the handle pulls off the splined shaft.
joe_padavano is offline
Old July 2nd, 2018, 08:43 AM
Apollo's Avatar
Thank you Joe. How is the backing plate secured to the door panel please?
Apollo is offline
Old July 2nd, 2018, 09:58 AM
My442's Avatar
It is held on by the armrest screws.
Once you take off the armrests, the backing plates fall of.
My442 is offline
Old July 2nd, 2018, 01:31 PM
dalilama's Avatar
IIRC there are some tension clips that hold the backing plates onto the door panel in a few places. If the backing plates just fall out after removing the arm rests the tabs that the clips grab onto probably broke off. No big deal as the armrest will hold the backing plate. You really need to remove the door panel to get the clips off.
dalilama is offline
Rick P. Schultz
June 9th, 2017 01:38 PM
Miles71
January 31st, 2017 05:03 AM
davoaz
March 31st, 2015 06:40 PM
MJAKS462
October 14th, 2010 09:38 AM
silverriff
April 24th, 2010 12:33 PM
Quick Reply: Door backing plates - 72 CS
