72 Cutlass LED Dash Light Replacement?
Old March 19th, 2018, 05:30 PM
72GoldOlds350's Avatar
Question 72 Cutlass LED Dash Light Replacement?
Hello,
Simple question; the dash lights on my 1972 Cutlass Supreme all work well and light up as much I need, with exception of the 4 light bulbs that are covered by the blue tinted plexiglass/plastic. These are the small bulbs that light up the AC controls, etc.
Seems like the bulbs are easy to replace - but are there easy LED replacements that are a bit brighter? For stock, they barely light anything up at all.
Thank you all so much!
72GoldOlds350 is offline
Old March 20th, 2018, 06:42 PM
Even a part number would be good!
I figured either 1) No one has done this because they don't care that much or 2) this is an easy question that everyone has done. Ha!
I searched, but no luck. Has anyone swapped out those 4 little bulbs with a multi-directional LED for better light?
Old March 21st, 2018, 11:02 AM
oldolds88's Avatar
I have no experience with leds. but I would try it anyway. but that's me
oldolds88 is offline
Old March 21st, 2018, 01:30 PM
troyd's Avatar
I've done it.....and prefer the standard bulbs. I like the dimmer "mood lighting" effect. The LED's make me feel like I'm getting softened up to be interrogated. Maybe it's just me.
The sockets on the ends are a real PITA to get at if you have fat fingers like me, and all things being equal, I'd just leave them be and spend that time reorganizing my sock drawer or something of that nature.
As always, YMMV.
Cheers,
Troy
troyd is offline
Old March 22nd, 2018, 04:53 PM
As always, YMMV.
Cheers,
Troy
Thanks for the heads up. I just realized one of the 4 bulbs is burnt out. I'm probably going to go ahead and replace all 4 of them. I just removed the dash plaque and thought it would be easy to get to them, but now I'm not sure how!
Old March 24th, 2018, 10:48 AM
Do I get to these light bulbs from under the dash? I was bummed to find out the bulbs are blocked off when you take the gauge bezel and blue plastic light covers off, even though they are right there!
Old March 25th, 2018, 06:33 AM
72cutlassconv's Avatar
You'll need to remove the gas gauge and the clock. Once you remove those two, you'll have access to replace these bulbs.
72cutlassconv is offline
Old March 25th, 2018, 10:54 AM
Right on - thank you so much! I appreciate it.
Old March 25th, 2018, 11:16 AM
troyd's Avatar
I pulled all three gauges and did them all at once, to include the lights in the gauges........no sense having to do that again any time soon. Again, nothing super difficult....just a PITA, but patience and a cold beverage and it's all groovy.
Cheers,
Troy
troyd is offline
Old March 25th, 2018, 10:38 PM
Cheers,
Troy
Makes sense! Thank you!
Im going to check if those bulbs are easy to find tomorrow after work.
Old March 27th, 2018, 08:29 AM
troyd's Avatar
The bulbs are very easy to find.........Amazon.com is your friend!
Any auto parts store has them but they are cheaper online......so, it's a confliction for me. I'm a tightwad but I'm also the poster boy for instant gratification.
Cheers,
Troy
troyd is offline
Old March 28th, 2018, 06:54 PM
Are those 4 bulbs that light up the HVAC controls under the clear blue/green plastic lenses the same bulbs as instrument panel bulbs?
Old March 29th, 2018, 07:30 AM
troyd's Avatar
All the ones in the dash are interchangable.....off the top of my head, I believe the book lists some of them as 168's and some 194's.....but I used all 194's.
I could be off on the #'s but the idea is that you can use the same ones...ever see Mr. Mom? What did you use? A .38? .38, .39...whatever it took.
Cheers,
Troy
troyd is offline
Old March 30th, 2018, 06:31 PM
Haha, sounds good! I only asked because I saw a lot of different bulb designs from the websites I went to, but all were cheap. I'll probably just get a bunch of each style as they were all really cheap. I just do not want to have the wrong bulbs when I have the dash partially apart.
White_Knuckles
January 20th, 2016 10:58 PM
66 Olznut
June 19th, 2015 01:47 PM
pfergy600
August 14th, 2014 11:26 AM
craftsmen22
January 11th, 2012 02:32 PM
Pfiffle
October 5th, 2009 04:32 AM
Quick Reply: 72 Cutlass LED Dash Light Replacement?
