Clock Lens removal
Old November 9th, 2017, 05:56 PM
GreekDog's Avatar
Clock Lens removal
hello everyone!
I am in the process of refurbishing my dash and gauges on my 72 cutlass. I have removed the gauges in anticipation of putting in new lenses. All of the lenses have come off easily except for the clock. The lens is caught up on the adjusting pin.
I know it’s a simple question but how do I go about removing the lens on the clock? I didn’t want to keep trying different methods because i was worried i may break the pin
GreekDog is offline
Old November 9th, 2017, 06:29 PM
oldspackrat's Avatar
I push the rubber sleeve down just a little bit & grip the stem with a pair of pliers & then Gently unscrew the **** from the stem. If it does not come loose easily, I hold the stem with a pair of pliers & use a small torch on the **** for several seconds & then use another pair of pliers to gently try to loosen the ****. This USUALLY works.
Good luck,
Scott
oldspackrat is offline
Old November 11th, 2017, 06:55 AM
GreekDog's Avatar
Good luck,
Scott
thanks! Worked like a charm
GreekDog is offline
tdhill01
June 21st, 2016 05:46 AM
BeenThere
May 31st, 2014 03:39 AM
nelsontj
March 1st, 2011 09:00 AM
lakidd135
August 5th, 2009 09:43 AM
Olds luvr
October 20th, 2007 04:50 PM
Quick Reply: Clock Lens removal
