1968 Courtesy Light Question
Old September 20th, 2017, 07:21 AM
jpmooning60's Avatar
Hello...I have a 1968 Cutlass Convertible that has a courtesy light under the dash on the drivers side. Currently this light works as it should when the door is opened but has no protective lenses.
If this light does indeed have a lense...could someone send me a picture of what it looks like?
Thanks for the help in advance!!
Tim
jpmooning60 is offline
Old September 20th, 2017, 09:59 AM
allyolds68's Avatar
Tim
it's a bare bulb mounted in the recessed strip on the underside of the dash metal, facing downward.
allyolds68 is offline
Old September 20th, 2017, 10:20 AM
And there should be one on each side, not just the driver's side.
joe_padavano is offline
Old September 20th, 2017, 10:26 AM
Thanks Joe - the drivers side bulb was missing and the (2) wires inside the socket kept touching and blowing the 25 amp fuse that controls the interior lighting.
Bulbs installed push the wires back down into the socket and keep them positioned away from each other - no dangling wires
Tim
Old September 20th, 2017, 12:04 PM
allyolds68's Avatar
It should have a bulb socket similar to this although I think this is actually one for the rear armrest courtesy lights:
https://static.summitracing.com/glob....jpg?rep=False
53oldsmobile
July 12th, 2017 05:58 PM
NINETY_EIGHT_REGENCY
May 18th, 2014 07:12 PM
442dale
February 16th, 2013 07:29 PM
derek nesdoly
June 12th, 2009 03:00 AM
Denm33
May 28th, 2008 07:35 PM
Quick Reply: 1968 Courtesy Light Question
