Rubber floor mats
Rubber floor mats
I just picked up some rubber floor mats for my 69 442 but I have a question. I noticed that they have a thin circle where the bright light switch is. Is the mat supposed to lay over the switch or should the hole be cut out so the switch goes through the mat?
I had carpeted mats in my 77 442 and they had a grommet to fit around the switch
The repro mats need the headlight dimmer switch hole to be cut out. You can use an exact knife or a proper size hole saw on your drill. This is the same thing with the repro trunk mats. They need the oval cut out for the Jack tie down
Year One. I only went with them because I had a discount. I originally was going to purchase from The Parts Place since they were cheaper but my discount made them the same price
They are decent weight but lighter than I expected. Overall I'm satisfied with them
Eric,
They are the same consistency and design as OEM. Only available in black as repros though. That would work well in your car. IMO they do smell a bit until they get aired out.
misercola
December 2nd, 2013 09:45 AM
Delmont 88 425
December 2nd, 2010 01:24 PM
