PUI Window Felts
PUI Window Felts
I have a set of PUI window felts I got for a song. Trynig to install, and besides the misaligned holes I only have one question: on side has chrome attached and the other is just rubber. Do i assume the chromed side attaches to the door panel?
Thanks for any feedback.
Post a pic.
Can't tell from what you've written if you are trying to differentiate b/n INNER and OUTER window sweepers OR if you are instead talking about just one strip style and trying to figure out which side of the strip rests against the panel.
Both inner and outer window sweepers will have "chrome" on them (ie- stainless steel).
Post a pic.
Never seen the outers without some type of exposed stainless raised "bead" running down the length of each strip.
Yours may have it and it may be covered with a peel-away layer over the stainless bead.
There is no stainless bead. Did a little more searching, apparently PUI has 2 kits Standard and OE style. This one is standard. Doesn't bother me because i prefer the rubber only on the outside.
sixty9olds
September 29th, 2010 08:00 AM
