Replace 6-way power front bench with manual?
1972 Vista Cruiser. My front bench is a 6-way power unit and it is not only completely trashed, but the motor is also barely functional and the seat is stuck in a pretty high upright position and pretty close to the wheel. I'm 6'5", so I'm kinda squeezed into my wagon when I drive it.
My question: do regular bench seats bolt directly in place of the fancy 6-way power bench? Or is there someone who knows how to refurbish these power bench seats so that I can at least scoot it back a little more and adjust the backrest?
Hi, if the power seat is original, it should be a 4 way, not 6 way. The 4 way control panel will have just the joystick, the 6 way will have the joystick and 2 buttons on either side of the joystick, they look like the power window switches. I have a '71 VC with the 4 way seat, I'm only 6' and the seat does not go back far enough. The manual tracks were different that the power tracks in the back but IIRC the front is the same. I don't think the manual will buy you anything. I'm planning to make some adapter plates to allow the seat to move back 1 or 2" and am thinking of a 6 way setup, maybe even a nicer seat, like the strato bench that the Eldos, Toros & Rivs had. The mechanism is not that hard to pull and repair, I seem to remeber several posts here ot just Google it. I do have a name of a repair place, I think in the Chicago area. Let me know I can dig up the info if you want.
I bought these for my bench seat int he Cutlass. With my girls we had the opposite problem, we needed to get the seat an inch closer. They told me no one ever asked that question before but I just flipped them and they work.
http://www.ebay.com/itm/332034434367...%3AMEBIDX%3AIT
How can I adjust the angle of the backrest so it's not so upright? Is there an adjustment for this, or is it just fixed?
jonosso
August 5th, 2022 07:14 AM
ryneves
May 8th, 2015 06:57 PM
1973olds98
Drivetrain/Differentials
August 17th, 2010 11:48 AM
