Replacing Carpet - Throttle Pedal Removal
Old December 10th, 2016, 12:11 PM
beamjp's Avatar
Hello,
I am replacing the carpet in my 1961 Dynamic and need to figure out how to remove the throttle pedal. I was under the car and can see a plate with two screws coming through, but I can see the top of the screws inside the car.
I don't know how to remove the pedal from the throttle bell crank under the dash, any hits would be appreciated.
thx
beamjp is offline
Old December 10th, 2016, 12:26 PM
2blu442's Avatar
I'm not experienced with the 1961 vintage. But I have encountered other years that had two fasteners at the base of the throttle pedal. They had a hex shaped stud with a round ball at the top. The gas pedal had two rubber "sockets" that clip over these round ball shapes. You might be able to feel under the pedal or if your carpet is going in the garbage cut around the base of the pedal to try and feel for these shapes. One thing to be careful of is old stiff rubber can crack and break the socket like fitting when you pull the pedal off the studs.
If that's clear as mud let me know and I'll try to find some photos for you.
John
2blu442 is online now
Old December 10th, 2016, 01:42 PM
Yellowstatue's Avatar
If it's anything like a '57, it is just a ball and socket arrangement and you just pull it apart. The metal studs below just screw into the plate for replacement if needed. Put some white lithium on the ***** to re-install. Easy peasy.
Yellowstatue is offline
Old December 11th, 2016, 07:30 AM
beamjp's Avatar
Thanks, so I just put a flat blade screw driver between the floor and the pedal and pry up?
beamjp is offline
Old December 11th, 2016, 01:09 PM
Powerful fingers work well also.
Old December 11th, 2016, 02:09 PM
The risk is that if the rubber of the pedal is hard and brittle, you may damage the sockets that the two ***** snap into.
joe_padavano is offline
Old December 11th, 2016, 02:13 PM
2blu442's Avatar
This is off a different year, but I'm expecting it to looks something like this.
Old December 11th, 2016, 02:15 PM
This is what those "screws" you are seeing look like.
Here you can see the holes in the underside of the pedal that the studs snap into.
Damn. Beat me to it.
defiant1
February 4th, 2020 08:53 PM
trevor1400
August 31st, 2016 03:15 PM
milesmonte
March 23rd, 2015 07:31 AM
rcktdoc
February 28th, 2014 08:37 AM
oldspackrat
March 30th, 2013 04:57 AM
Quick Reply: Replacing Carpet - Throttle Pedal Removal
