rear seat removal tip
Old February 2nd, 2015, 02:39 PM
Macadoo's Avatar
Just thought I'd share. For those of us that are either too large to fit back there or can't get the needed leverage to push that rear seat backward, or in my case, it had never been removed and was quite stuck. Be sure to spread the load over a large area so the surface doesn't get marred. It takes a little fiddling with the wood lengths but once you hammer that center plank down, the seat pops back and comes right out.
Hope this helps someone
[IMG][/IMG]
Macadoo is offline
Old February 2nd, 2015, 02:57 PM
oldspackrat's Avatar
Nice tip! I've strained way to many times trying to pop those things out.
oldspackrat is offline
Old February 2nd, 2015, 03:09 PM
Macadoo's Avatar
I hear that. I have a bad right shoulder from too much abuse.
Macadoo is offline
Old February 2nd, 2015, 04:22 PM
Need blueprints with board dimensions!
Fun71 is offline
Old February 2nd, 2015, 04:38 PM
Sammy70 455 Supreme
sammy's Avatar
Great tip! Have any to get it back in?
sammy is offline
Old February 2nd, 2015, 04:42 PM
Macadoo's Avatar
I actually kept the boards, marked them with a sharpie. Wouldn't it be a little different for each car though? I know your [half] kidding but I could get the dimensions.
Good point. I DID have to use the same procedure to get them back in. I'd forgotten that. Used the boards to push it back into place and then plopped my behind onto the seat. Worked like a charm.
Macadoo is offline
Old February 2nd, 2015, 05:20 PM
RandyS's Avatar
I have found that using my knee, like you would on a carpet kicker, works just fine for out or in.
RandyS is offline
Old February 2nd, 2015, 08:59 PM
That only works on Saddle or Sienna trim interiors....
Seriously - cool idea. I think I'd use 2x6 or 2x8 on the front of the seat though to spread out the force better. On second thought maybe I should use smaller dimension wood to remove the finger prints of the peeps who sat back there while I gave them a test drive...
Allan R is offline
Old February 3rd, 2015, 04:23 PM
Macadoo's Avatar
[IMG][/IMG]
Yeah, that would have been better. But notice the slant to the front board. That was necessary in order to create the wedge so I couldn't just have turned it on it's side. 2x8 or even 10 might work. But really though, the 2x4 didn't leave a mark.
Macadoo is offline
Old February 4th, 2015, 03:01 AM
Yellowstatue's Avatar
You should number those boards so that you don't get them mixed up next time you use them.
Yellowstatue is offline
Old February 4th, 2015, 04:08 AM
Macadoo's Avatar
Next time ?!?
Macadoo is offline
Old May 29th, 2015, 10:13 PM
johnnyjaws's Avatar
very good idea...
johnnyjaws is offline
Old May 30th, 2015, 06:16 AM
Macadoo's Avatar
Thanks Johnny. I've used it a couple of times since I started this thread. I'm glad I kept the boards, lol.
Macadoo is offline
Old May 30th, 2015, 12:46 PM
You need to make another set & put them on ebay, I guarantee someone will buy them!
Old May 30th, 2015, 01:47 PM
Macadoo's Avatar
Hmm, maybe paint them? Color coded?
"Rear Seat Removal Tool: RARE! $500.00, Free Shipping!"
Lol.
Macadoo is offline
Crazy88
July 15th, 2009 05:39 PM
Nilsson
May 18th, 2009 09:20 AM
gearheads78
February 14th, 2009 10:06 AM
Dapapadon
February 2nd, 2009 11:31 AM
csouth
December 15th, 2008 04:07 AM
Quick Reply: rear seat removal tip
