65-69 442 4 speed console correct black paint
Old July 6th, 2019, 09:42 PM
W-27's Avatar
I have a 68 442 4 speed and the console needs repaiting on the top plate in the front. Can anybody tell me what is the correct (Flat?) Black paint to use to do it and were i can purchase it? They are litarilly several hundred shades of flat black paint and i want to do this correctly. Thank you in advance.
W-27 is offline
Old July 7th, 2019, 08:30 AM
Gpc1's Avatar
SEM Landau black. This information is from 442bro website. I use ace hardware satin black myself .
Gpc1 is offline
Old July 7th, 2019, 08:37 AM
MI68442W30's Avatar
um no , SEM trim black is the paint to use!
MI68442W30 is offline
Old July 7th, 2019, 10:29 PM
W-27's Avatar
Thank you everyone for your imput. I ordered a can of SEM 39143 Trim Black from an eBay seller. Hopefully this will be the perfect match.
W-27 is offline
Old July 8th, 2019, 04:30 AM
35tac's Avatar
A little late but why would you not paint both the front and back plates and not have to endure a possible mismatch. Then you could use your choice of finish. I used Rustoleum Appliance Epoxy Black 20066 78868. Just saying.
Wayne
35tac is offline
Old July 8th, 2019, 10:16 AM
W-27's Avatar
Wayne, i plan to paint the entire console and replace worn out booth. This is exactly why i want to use as close to the original paint color as possible.
W-27 is offline
Old July 8th, 2019, 11:51 AM
35tac's Avatar
Thats good. Like to see a picture when its done. Are you going to strip the old paint. Thats what I found was the most tedious part. Well worth it when it's done. I didn't think so until I got about half way thru.
Wayne
35tac is offline
Old July 9th, 2019, 07:11 AM
allyolds68's Avatar
I can't really speak to what sheen the console top plate and glove box plate were originally because mine were flaking so badly but I can tell you that SEM Landau Black was an exact match to the original console base and also the metal dash on my 68.
allyolds68 is offline
Old July 9th, 2019, 07:26 AM
W-27's Avatar
Perhaps i will try both on a piece of card board then decide.
W-27 is offline
Old July 11th, 2019, 07:39 AM
MI68442W30's Avatar
with all due respect SEM landau black is a VINYL DYE not a paint, and is not formulated for metal nor would I use it for that purpose, whereas the SEM trim black is formulated for just this purpose,TRIM, metal or plastic, hence the name TRIM BLACK , and the question was what is the correct paint to use? not what did you use! SEM trim black is an exact match!
Old July 11th, 2019, 10:40 AM
W-27's Avatar
Coffee is for closers
Now that's what i call a close. I will use the SEM trim black. Thank you.QUOTE=MI68442W30;1184430]with all due respect SEM landau black is a VINYL DYE not a paint, and is not formulated for metal nor would I use it for that purpose, whereas the SEM trim black is formulated for just this purpose,TRIM, metal or plastic, hence the name TRIM BLACK , and the question was what is the correct paint to use? not what did you use! SEM trim black is an exact match![/QUOTE]
W-27 is offline
johns65442
January 21st, 2014 01:35 PM
dfire25
December 3rd, 2012 08:24 PM
501Paratrooper
April 1st, 2011 12:31 PM
texasred
Care and Appearance
March 11th, 2011 08:22 PM
72supremebeing
May 8th, 2010 07:51 PM
Quick Reply: 65-69 442 4 speed console correct black paint
