Lightning Rods Repair/Rebuild Service
I have had quite a few requests over the years to repair and rebuild Lightning Rods shifters so I am making my services available to those needing their shifter repaired or rebuilt to function properly again.
As long as your shifter is complete and not missing any parts I can get it to function like new again.
Mechanical refurbishing service: includes cleaning of all mechanical parts, new rod cables, clip and set screw replacement as needed, worn pin channels and cam journals narrowed on the rods to eliminate slop, proper adjustment.
Cosmetic refurbishing includes: polishing of all chrome and ****, stripping, neutralizing and bluing of base and pawl. High speed polishing of mechanical moving parts.
All mechanical work guranteed for as long as you own your car.
Repair welding of broken gate pins also available $50 each, inquire with needs.
Inquire via PM and I can quote my services to you based on your needs.
Thanks!
Example of my work:
Thanks!
Example of my work:
Lightning rod shifter repair
Sir I’m new here an i saw your post I would like you to give me some advice thanks in advance l have a nice lightning rod shifter with over drive but I need one for a turbo 400 William in louisburg nc thanks again
Broken pin repair
Shattered spring retaining C-clip replacement
Snapped or stretched wires
New ****
Proper adjustment and lubrication
Thanks!
Example of my work:
Attachment 158991
Broken pin repair
New ****
Thanks!
Example of my work:
Attachment 158991
Thanks for the info. That’s what I thought but hoped it would be easy/simple. Found a NOS universal shifter in great shape locally for a 350/400. I currently have a 350th but have a 200r4 I’d like to eventually build and install in my 72’ Chevelle.
Broken Lightning Rod!
Broken pin repair
New ****
Thanks!
Example of my work:
Attachment 158991
Broken pin repair
New ****
Thanks!
Example of my work:
Attachment 158991
Thanks!
Thats awesome boss. Gladl to know we have someone who can do repairs.
Example of my work:
Attachment 158991
Thanks!
Example of my work:
Attachment 158991
88hurstolds
June 18th, 2014 04:50 PM
