68 h/o paint questions
Is there any black in the door jamb when demmer painted black on the lower part of the car? Did they tape the jamb off, add a clean cut portion of paint in the jamb or is there sloppy overspray? Also what is the approx size of the white pinstripes? (1/8" ? )
It was sloppy over-spray.
When I did mine, I masked it clean about 1/4" into the jamb and around the door hems.
Was told by Judy Badgely that this was acceptable for judging.
I have some drawings I made from original paint cars I measured. Someone had done some drawings for the 69 and I redid them them for the 68. If you want a copy to look at, PM your email and I'll send you a set. I have some jamb pics as well.
Ended up free-handing a lot of the curves to make it look better.
Good luck!
Joe
Good luck!
Joe
jensenracing77
Paint
September 10th, 2014 02:33 PM
JpMotorsports
May 15th, 2014 07:08 AM
