69 ho id.
Old January 29th, 2014, 09:47 PM
montvaleplace's Avatar
69 ho id.
Were all the HOs built in Lansing like w30's? What should the data tag have for the paint code? 50-50?
montvaleplace is offline
Old January 30th, 2014, 05:22 AM
Lansing built
1970cs's Avatar
Yep, all of the H/O's were made in Lansing! I will have to look into the cowl tag for you.
Pat
1970cs is offline
Old January 30th, 2014, 05:37 AM
morgan
pogo69's Avatar
yes and yes
pogo69 is offline
Old January 30th, 2014, 09:00 AM
69 ho
So there wasn't a - - or a stripe color code? just 50 50.
Old January 30th, 2014, 10:03 AM
morgan
pogo69's Avatar
right just the 50/50
pogo69 is offline
Old January 30th, 2014, 10:12 AM
morgan
pogo69's Avatar
all the cars left the factory cameo white and the stripes were added after the car left the factory...along with other H/O package parts
pogo69 is offline
Old January 30th, 2014, 02:17 PM
firefrost gold's Avatar
They all had D heads , air con or non air cars alike. Do you have one one the line ??
firefrost gold is offline
Old January 30th, 2014, 02:39 PM
69 ho
There is the possibility!
Old January 30th, 2014, 07:33 PM
What should I be looking for in the way of documentation? Broadcast sheets, build sheets, and window stickers would be nice but what about Hurst specific things?
Old January 31st, 2014, 07:15 AM
The only "Hurst specific" thing you are likely to find is the tire pressure decal on the edge of the driver's door. Note that these are available as repros.
joe_padavano is offline
Old January 31st, 2014, 07:59 AM
morgan
pogo69's Avatar
if you have some pics post them to better determine what you may have or found
pogo69 is offline
Old January 31st, 2014, 09:22 AM
mmurphy77's Avatar
Also, cowl tag will ONLY have '33687LAN', '50 50' (Cameo White) paint code and '930' (Black bucket seat) interior code and build dates ONLY between 3D to 5E (4th week of March to 5th week of May respectively).
mmurphy77 is offline
Old January 31st, 2014, 12:14 PM
As soon as I get to see (them) I will post what I find and take some pics. Looks like it will be next week sometime.
Old January 31st, 2014, 03:14 PM
And what is different about the door tag than a 442? How can I tell a fake? The v.i.n. doesn't start with 344 so any cutlass could be dressed up as a HO?
Old January 31st, 2014, 04:24 PM
http://hurstolds.oldsgmail.com/69hoinfo.htm
Old January 31st, 2014, 04:47 PM
morgan
pogo69's Avatar
the door tag tire pressure decal differs from the 442 in part because the H/O had 15 inch tires with the weight of a 455. unless its a convert it has to start 344
pogo69 is offline
Old February 1st, 2014, 07:52 AM
This:
Huh?
The COWL TAG doesn't start with 344..., because the ones on Lansing-built 442s didn't either for most of the 1968-69 model years. This is well documented in the Fisher Body Manual for those years. The VIN absolutely DID start with 344... for all 1968-69 442 and H/Os.
The weight of a 455 is within a couple of pounds of the weight of the 400 that was in the 442s.
Huh? Are you saying that the 1969 H/O converts weren't based on 442s? All 69 442 convertibles absolutely did start with 344... VINs.
Old February 1st, 2014, 08:22 AM
morgan
pogo69's Avatar
344 879 vs 679 was my point here
pogo69 is offline
Old February 1st, 2014, 09:10 AM
NôôB
sicky olds's Avatar
also compare the vin to the Demmer list is another way to see
sicky olds is offline
Old February 1st, 2014, 01:44 PM
Is there a list on this site somewhere, because that would pretty much exclude the fakes..
Old February 1st, 2014, 04:01 PM
Octania's Avatar
"The weight of a 455 is within a couple of pounds of the weight of the 400 that was in the 442s. "
Since the only difference between the '69 400G and the '69 455F is the bore size/ piston size, I'd say the weight discrepancy would be on the order of 5-10 lbs at the most. Well, there is that extra boss on the intake, and a second rocker cover breather...
here is the link to many of the known VIN's
http://hurstolds.oldsgmail.com/69hovin.htm
Octania is offline
