'68 His/Hers bracket location
Old June 11th, 2013, 09:58 AM
Mike H.'s Avatar
Sorry, I posted this in the wrong forum.
I'm putting a dual gate in a '68 cutlass. I would really appreciate any kind of measurements or pictures of the his/hers bracket location and cable hole.
Thanks, Mike
Mike H. is offline
Old June 11th, 2013, 11:30 AM
firefrost gold's Avatar
You going with a 68 H/O set up or what I dont beleive the 68 had the dual gate like the pontiac.
firefrost gold is offline
Old June 14th, 2013, 07:57 AM
Mike H.'s Avatar
How about some dual/gate measurements or pics of a '69 H/O set up then? Anyone? Anyone?
Mike H. is offline
Old June 14th, 2013, 07:30 PM
https://classicoldsmobile.com/forums...e-bracket.html
I pmed mark to see if he by chance had this one I helped him out with . Maybe well get lucky
Old June 22nd, 2013, 06:10 PM
Mike H.'s Avatar
Firefrost, thanks for the help. This has been more difficult than I thought to get some accurate measurements. The thread you posted helped some too. Thanks again
Mike H. is offline
Old June 22nd, 2013, 08:01 PM
Tom442's Avatar
Dual Gate
Well...I can give you my measurements where I installed my DualGate...it was really more of a guess where I put it. Where the feet fit and where it looked right with the mini console on. Someone with a 68 HO or 69 could chime in with a simple measurement from say..instrument panel to gear shift **** in park for a good North/South dimension. Sorry to say the shifter seems to go through all its positions but I am so close at firing it up again and getting it on the road. Geez, I sound like a broken record.
Tom
68 442
70 F85
Tom442 is offline
Old July 12th, 2013, 12:35 PM
Mike H.'s Avatar
Tom, did you use the same cable hole location used for the standard floor shifter? BTW, I located the shifter itself using your method. Now, I'm just trying to figure out how to run the cable through the floor pan
Mike H. is offline
Old July 12th, 2013, 01:00 PM
Tom442's Avatar
IIRC...Yes,
I think I used the spot for the factory console...Mine was a column shift so I started from scratch..EXCEPT looking for some pics here at work of the location of the hole for the cable..I found a pic someone on the forum sent (thank you again!) with some measurements for the shifter. Sorry, a bit lit on that i guess. Correct me Dual gate guys if I am wrong but it seems like the dual gate cable ends up almost "S" shaped. Same for regular console cable I assume?
Tom
Tom442 is offline
Old July 14th, 2013, 03:18 PM
Mike H.'s Avatar
Tom, I really appreciate the pics and comments. The 'S' shaping of the cable makes sense. Thanks again, Mike
Mike H. is offline
dfire25
March 19th, 2013 11:37 AM
1970supremevert
December 16th, 2012 10:22 PM
1970supremevert
December 16th, 2012 05:59 AM
fast67vellen2o
June 9th, 2012 03:31 PM
tim72
April 1st, 2009 08:14 PM
Quick Reply: '68 His/Hers bracket location
