correct location of ignition coil
Old May 8th, 2013, 08:04 AM
morgan
pogo69's Avatar
i'm replacing my ignition coil and was looking in the 1969 service manual sec 12 page 49...it shows the positive coil terminal on the left side of car, now my old one has the pos. terminal on the pass side...what is correct?
pogo69 is offline
Old May 8th, 2013, 09:22 AM
Octania's Avatar
seriously?
Positive on TOP!
I don't think it matters, as long as the wires reach the terminal they need.
(-) closest to distributor would make sense.
Octania is offline
Old May 8th, 2013, 02:25 PM
morgan
pogo69's Avatar
Ok here is why i want to know...if the negative is on the right as i am facing it(left side of car) then the delco remy is readable....if the positive terminal is on the left the delco remy is upside down BUT the embossed 238 b-r is readable and on top the embossed number would be on the bottom of the coil with the neg post on the left
pogo69 is offline
Old May 8th, 2013, 03:46 PM
Randy C.
rcorrigan5's Avatar
I don't know if this is relevant or not - different engines and different assembly plants - but here's how the coil is mounted in my '69 Fremont 4-4-2. I don't have any reason to believe it has ever been removed and re-installed - it's pretty crusty under the hood. The (-) terminal is inboard.
Randy C.
rcorrigan5 is offline
Old May 8th, 2013, 04:31 PM
morgan
pogo69's Avatar
Randy C.
thanks for the pic that is also how my old one was mounted but the service manual has it with the pos inboard i guess the manual could be wrong
pogo69 is offline
805cut
September 3rd, 2012 10:53 AM
stevengerard
February 14th, 2010 07:30 AM
OlBluehairCruiser
July 31st, 2009 08:33 PM
1FSTLS1
December 20th, 2008 05:45 AM
68conv455
February 20th, 2008 02:36 AM
Quick Reply: correct location of ignition coil
