Lightning Rods Repair/Rebuild Service
Old June 9th, 2015, 09:21 AM
www.gbodyolds.com
88hurstolds's Avatar
I have had quite a few requests over the years to repair and rebuild Lightning Rods shifters so I am making my services available to those needing their shifter repaired or rebuilt to function properly again.
As long as your shifter is complete and not missing any parts I can get it to function like new again.
Mechanical refurbishing service: includes cleaning of all mechanical parts, new rod cables, clip and set screw replacement as needed, worn pin channels and cam journals narrowed on the rods to eliminate slop, proper adjustment.
Cosmetic refurbishing includes: polishing of all chrome and ****, stripping, neutralizing and bluing of base and pawl. High speed polishing of mechanical moving parts.
All mechanical work guranteed for as long as you own your car.
Repair welding of broken gate pins also available $50 each, inquire with needs.
Inquire via PM and I can quote my services to you based on your needs.
Thanks!
Example of my work:
88hurstolds is offline
Old July 30th, 2015, 12:07 PM
gbodyguru's Avatar
Nice to know !! *Is there any "maintenance" one should do" ?? (mine are working fine NOW)
gbodyguru is offline
Old September 17th, 2015, 02:43 PM
www.gbodyolds.com
Lubrication and being gentle with them during operation is all I suggest.
And make sure your cable is not corroded or worn...
Old September 17th, 2015, 03:26 PM
gbodyguru's Avatar
OK, I popped the top off, *(funny: but the far right "button" didn't wanna unscrew tho*).
Anyway, I lubed it all up with a needle oilier, "everything seems fine".
Thanks for the tip !
Old July 14th, 2019, 06:46 PM
Tony Parrish's Avatar
Lightning rod shifter repair
Sir I’m new here an i saw your post I would like you to give me some advice thanks in advance l have a nice lightning rod shifter with over drive but I need one for a turbo 400 William in louisburg nc thanks again
Tony Parrish is offline
Old October 5th, 2019, 11:11 AM
Big Johnson's Avatar
Looking for parts I need about ten of the cables that operate the push button do you have those thanks 253 397 6016
Big Johnson is offline
Old October 5th, 2019, 05:39 PM
Sorry I don’t any shifter parts
Old December 15th, 2019, 09:24 AM
7toomaliboo's Avatar
Broken pin repair
Shattered spring retaining C-clip replacement
Snapped or stretched wires
New ****
Proper adjustment and lubrication
Thanks!
Example of my work:
Attachment 158991
Can a 3 speed setup be converted or modified to work with an OD transmission? Thanks!
7toomaliboo is offline
Old December 15th, 2019, 11:41 AM
69HO43's Avatar
Nothing a different detent which would need to be welded, different gate, and different pivot rod can't fix. In short, you'd be better off trying to find an OD set of rods.
69HO43 is online now
Old December 15th, 2019, 11:59 AM
Thanks for the info. That’s what I thought but hoped it would be easy/simple. Found a NOS universal shifter in great shape locally for a 350/400. I currently have a 350th but have a 200r4 I’d like to eventually build and install in my 72’ Chevelle.
Old November 29th, 2020, 02:14 PM
Tina McGowan's Avatar
Broken Lightning Rod!
Broken pin repair
New ****
Thanks!
Example of my work:
Attachment 158991
Hello, I have a lightning rod shifter with a broken cable in the main stick, is this something you can repair or have on hand to purchase for self repair.Thank You Mark McGowan
Tina McGowan is offline
Old November 30th, 2020, 07:54 AM
www.gbodyolds.com
Yes I can repair the shifter, PM me.
Old May 25th, 2023, 07:52 PM
www.gbodyolds.com
Just finished these for a member in Canada.
Old May 28th, 2023, 03:19 PM
Jusrushem's Avatar
Thanks!
Thats awesome boss. Gladl to know we have someone who can do repairs.
Example of my work:
Attachment 158991
Jusrushem is offline
88hurstolds
May 1st, 2016 06:30 AM
Octania
July 12th, 2015 08:12 PM
88hurstolds
October 14th, 2014 12:05 PM
88hurstolds
June 18th, 2014 04:50 PM
golow1
Hurst/Olds
February 1st, 2014 08:45 PM
Quick Reply: Lightning Rods Repair/Rebuild Service
